Configuring Clickable Websites
You can create a list of websites that users can launch from user defined fields (UDFs), projects websites, Team Member Web, and Notebook topics. In P6 Team Member Web, users launch sites from the dropdown icon next to the site.
To configure a website to be clickable:
  1. On the  Navigation Menu, expand  Administration, then click Application Settings.
  2. On the Application Settings page, click Integration & Allow Lists.
  3. On the Integration & Allow Lists page, in the Site Allow List section, click Edit List.
  4. In the Site Allow List dialog box:
    • To add a website to the list, click  Add (Ins) then enter the website URL.
    • To allow users to open a website from its link, mark the  Selected option on that row.
    • To delete a website from the list, click  Context and select Delete.
  5. When you have finished configuring the list, click Save.
Tip
Here are some rules on how to specify websites:
In this situation, the website https://apps.magnacorp.com will be clickable, because the template including the wildcard * is selected.
Related Topics
Configuring Integration & Allow Lists Settings
Linking P6 and Primavera Unifier Applications Using Schedule Sheets
Configuring Allowed Client IP Address Ranges
Last Published Wednesday, April 1, 2026
