Add a view currency (P6 Professional Only)
- Choose Admin, Currencies.
- Click Add.
- Click the General tab, then type an ID that clearly identifies the currency type.
- Type the currency's name.
- Enter the symbol used to identify the currency.
- Enter the global exchange rate for the currency.
- Click the Appearance tab, then select the symbol used to separate whole values from decimal values in the currency display, for example, 500.5 or 500,5.
- Select the symbol used to separate groups of digits in the currency display, for example, 300,000 or 300-000.
- Select the number of decimal places to display in currency values, for example, none (70), one (70.1), or two (70.14).
- Select the format used to display positive and negative currency values.
Last Published Tuesday, January 6, 2026
