Assign role codes and values
  1. Choose Enterprise, Roles, then select the role to which you want to assign a code and value.
  2. Click the Codes tab.
  3. Click Assign.
  4. Select the role code value you want to assign.
    You can only assign one value per code.
  5. Click Assign, then click Close.
Tip
  • To change a code value assignment, double-click the code value you want to change and select a new code value.
  • To remove a role code, select the code and value you want to remove in the Codes tab, then click Remove.
Last Published Thursday, July 16, 2026
