Check out a project to XML
- Open the projects you want to check out.
- Choose File, Check Out...
- Select the projects you want to check out.
To check out a project, it must be open. If the project you want to check out is not on the list, click Cancel, open the project, and restart the wizard. - Optionally, for each project you selected to export, click Select.. in the Baselines to Export column, then select which baselines to export with the project.
- Select Check out to XML.
- Click Finish.
An XML file is created that exports complete project information to other P6 Professional or P6 EPPM applications.Note To move between different wizard windows, click Prev or Next.
Last Published Thursday, July 16, 2026
