Copy and paste a project
  1. Open the project you want to copy
  2. Choose Enterprise, Projects, then select the project you want to copy.
  3. Choose Edit, Copy, or click the Copy icon on the Edit toolbar.
  4. Select the position in the EPS where you want to copy the project.
  5. Choose Edit, Paste, or click Paste icon on the Edit toolbar.
  6. In the Copy Project Options dialog box, mark the checkbox next to each type of information you want to copy.
  7. Click OK.
    Note
    • You must group the projects by EPS in order to copy Summary Data.
    • If you select Do Not Show This Window Again in the Copy Options dialog box settings are retained until you reopen the module.
    • If you want to copy or move a project and have the copied or moved project's Responsible Manager value automatically changed to another value, then you need to first open the project to copy or move and group and sort the Projects view by Responsible Manager. Then copy or move the project to the appropriate responsible manager.
    • The administrator should not assign any of the following privileges to users who should not have access to view cost information while copying and pasting project/EPS or assigning WBS and Fill Down on the WBS column in the Activities view: View Project Costs/Financials, Edit WBS Costs/Financials, and Edit EPS Costs/Financials.
    • When connected to a P6 EPPM database: P6 Professional uses a job service to copy projects and EPS nodes. This means that you can carry on working while the project or EPS is copied in the background. To see the progress of the job, choose Tools, Job Status. You must group the projects by EPS in order to copy projects and EPS nodes using the job service.
Related Topics
Managing projects using the EPS
EPS (Enterprise Project Structure)
Last Published Thursday, July 16, 2026
