Copy Resource Options dialog box
The Copy Resource Options dialog box allows you to specify which information you want to copy when you copy a resource.
You may copy any or all of the following options:
Sub-Resources: Mark to copy all resources contained in the resource you want to copy.
Role Assignments: Mark to copy the resource's role assignments.
Prices: Mark to copy the resource's price information.
Do not show this window again: Mark to indicate that you do not want this dialog box to appear next time you copy a resource.
Note
If you mark Do not show this window again, the Copy Resource Options dialog box will not display again until you restart the application.
Last Published Thursday, July 16, 2026
