Cost Accounts dialog box
Use the Cost Accounts dialog box to maintain your organization's cost accounts. You can assign these cost accounts to activities in any project.
Display Options bar: Click to search for a specific cost account, change the cost account display, or print the cost account table.
Cost Account ID column: Lists IDs for cost accounts.
Cost Account Name column: Lists names of cost accounts.
Cost Account ID field: The selected cost account's ID. You can type a new ID.
Cost Account Name field: The selected cost account's name. You can type a new name.
Cost Account Description: A description of the selected cost account. You can only view the description in this field; to add or edit a description, you must use the HTML editor.
Modify: Click to add or edit the description for the selected cost account in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
Print: Click to print the displayed description.
Copy: Click to copy the selected text. After copying text, you can paste it into the HTML editor or into another application.
Add: Adds a cost account.
Del./Merge: Deletes the selected cost account. If the cost account is assigned to activities, you can choose to merge the cost account with another one.
Cut: Moves the selected cost account to a new position in the cost account structure. Select a new position, and click Paste.
Copy: Copies the selected cost account to another position in the cost account structure. Select an additional position, and click Paste.
Paste: Pastes a cost account that you have either copied or cut.
Arrows: Change the selected account's position in the cost account structure.
Last Published Thursday, July 16, 2026
