Create EPS-level activity codes
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining EPS-level Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Click Add to select the EPS to which you want to add the activity code.
- In the Activity Code Name field, type the name of the EPS-level activity code.
- In the Max Length field, specify the maximum number of characters for the activity code's values.
- Click Close.
Tip
To change the order in which EPS-level activity codes are listed, select the activity code you want to move in the Activity Code Definitions dialog box, then click Shift Up or Shift Down.
Last Published Thursday, July 16, 2026
