Customize activity column titles
- Choose View, Columns.
You can also click the Layout Options bar and choose Columns. - In the Available Columns or Selected Options section, select the column whose title you want to change.
- Click Edit Column.
- In the Edit Column dialog box, type a new title, then click OK.
You can also specify a new width and alignment for the column. - To update columns in the Activity Table, click OK, or to view your changes without closing the Columns dialog box, click Apply.
Note
- The default column title appears in parentheses after the new title in the Columns dialog box; however, only your revised title appears in the actual layout.
- To restore the default column title, click Default in the Edit Column dialog box.
Last Published Thursday, July 16, 2026
