Cut and paste expenses
- Choose Project, Expenses.
- Select the expense you want to cut, then choose Edit, Cut.
- When connected to a P6 Professional database: To add the cut expense to a specific project expense category, WBS, cost account, or vendor, click the Display Options bar, choose Group and Sort By, then choose the grouping option.
When connected to a P6 EPPM database: To add the cut expense to a specific project expense category, WBS, or vendor, click the Display Options bar, choose Group and Sort By, then choose the grouping option.
Select the grouping band to which you want to paste the cut expense, then choose Edit, Paste.
Last Published Thursday, July 16, 2026
