Cut, copy, or paste a statement
  1. Choose Tools, Global Change.
  2. Select the global change specification you want to edit, then click Modify.
  3. Select the statement you want to cut or copy, then click either Cut or Copy.
  4. Click the section into which you want to paste the statement.
  5. Click Paste.
    The new statement is placed at the bottom of the list of statements.
    Note
    You cannot paste statements from the If section of the Global Change dialog box into the Then or Else sections; however, you can cut or copy and paste between the Then and Else sections.
Last Published Thursday, July 16, 2026
