Delete an EPS node or project
- Choose Enterprise, Projects, then select the EPS node or project that you want to delete. Choose Edit, Delete.
- Click Yes to confirm.
Tip
When you delete an EPS node, all projects in that branch of the hierarchy are also removed. To save projects in a branch before deleting it, first copy and paste those projects to another area of the hierarchy.
Related Topics
Last Published Thursday, July 16, 2026
