Edit global activity code values
  1. Choose Enterprise, Activity Codes.
  2. Choose Global.
  3. Select the activity code whose value you want to change.
    To change a value name or description, double-click the item you want to change, then type the new text.
    To change the placement of the code in the list, click Shift Up or Shift Down.
  4. Click Close.
Tip
If you change an activity code value, your changes apply to all activity assignments.
Related Topics
Edit global activity codes
Last Published Thursday, July 16, 2026
