Edit resource code values
- Choose Enterprise, Resource Codes.
- Select the resource code whose value you want to change.
- To change a value or description, double-click the item you want to change, then type the new text.
Tip
If you change a resource code value, your changes apply to all resource assignments.
Related Topics
Last Published Thursday, July 16, 2026
