Import Layout As dialog box
Use this dialog box to select where the layout should be imported.
Layout Name: The name of the layout. You can type a new name.
Available to: The category of users who can access the new layout. You can select a different user category.
User: The user to which you want to assign the layout. Click
to select a user.
Project: The Project with which you want to associate the layout. Depending on the user privileges,
is enabled to permit selecting a project with which to save the layout.
Save: Saves the current layout according to the options you specify.
Cancel: Closes this dialog box without saving the current layout.
Note
- The User field is available only if the selected Available to category is Another User.
- Applied filters are saved with the layout.
- Applied User Defined filters become available as Global filters when a layout is saved to All Users.
- Project layouts are not available in project and tracking views.
- Project layouts are associated and available with the project and can be used to limit the number of layouts in the global section.
Last Published Thursday, July 16, 2026
