Importing Options -- Projects
If resource security is enabled (you have limited or no resource access), the following restrictions apply when importing activity resource assignments:
If you have no resource access, you cannot import activity resource assignments if the resource does not exist in the resource dictionary.
Last Published Thursday, July 16, 2026
