Project Issues window
Use the Project Issues window to add, edit, and delete issues for the open project and to send Email notifications about issues. You can customize the columns that display in the issue table, and you can group, sort, and filter issues.
To display the Project Issues window, do one of the following:
When working in the Project Issues window, you can:
Tip
Use the Issue Navigator dialog box to track the open project's issues. This includes associated activities, resources, and work breakdown structure (WBS) elements.
Note
  • After opening the Project Issues window, the window remains open until you close all open projects or you close the window; if you open or navigate to another window without closing the Project Issues window, click the Project Issues tab to return to the window at any time.
  • If resource security is enabled, you can only view resources you have access to (under the resource root node) and current project resources.
Related Concepts
Related Tasks
You can perform all of the following tasks in the Project Issues window:
Related Topics
Project Toolbar
Menu bar
Edit Toolbar
Layout Toolbar
Project Issue Details
Bottom Layout Toolbar
Use the issue navigator
Introduction to Resource Security
Root Node
Current Project Resources
Issues
View or add to an issue's history
Track the duration of an issue
Send Email about an issue
Delete an issue
Change an issue's status
Assign an issue to an activity
Assign an issue to a resource
Assign a tracking layout to an issue
Add an issue
Last Published Thursday, July 16, 2026
