Promote project-level activity codes and values
You can promote, or change, a project-level activity code and its values to a global or EPS-level activity code with global or EPS-level values.
  1. Choose Enterprise, Activity Codes.
  2. Choose Project, then click Modify.
  3. Select the code you want to promote, then click Make Global or Make EPS.
  4. Click Yes, then click Close.
Tip
If you promote a project-level activity code and its values, your change applies to all activity assignments.
Last Published Thursday, July 16, 2026
