Select Primary Resource dialog box
Use the Select Primary Resource dialog box to select the primary resource for an activity.
Display Options bar: Lists options for changing resource columns, filters, grouping and sorting, font, and colors.
Search: Type a resource ID or name to display a filtered list of resources whose ID or name begins with this value.
Resource ID: Lists the ID of each resource in your organization.
Resource Name: Lists the name of each resource in your organization.
Primary Role: Indicates the primary role assigned to a resource.
Default Units/Time: Lists the default units/time for each resource in your organization.
Select: Applies your selection and closes this dialog box.
Clear: Removes the selected resource from your current activity.
Note
- If resource security is enabled, you can only select resources from under the resource root node you have access to or from current project resources.
Related Topics
Introduction to Resource Security
Last Published Thursday, July 16, 2026
