Select Replacement Funding Source dialog box
Use the Select Replacement Funding Source dialog box to select the funding source to which you want to reassign a deleted funding source's assignments.
Display Options bar: Click to change the font or colors in this dialog box.
Funding Source: Lists the funding sources defined for the enterprise.
Select: Reassigns the deleted funding source's assignments to the selected funding source.
Last Published Thursday, July 16, 2026
