Select Resource Code and Select Role Code dialog boxes
Use the Select Resource Code dialog box to select the resource code to filter by in the Resource Codes dialog box. Use the Select Role Code dialog box to select the role code to filter by in the Role Codes dialog box.
Display Options bar: Click to change the display.
Resource Code or Role Code: Lists the available resource codes or role codes.
Select: Assigns the selected code to the filter.
Last Published Thursday, July 16, 2026
