WPs & Docs window
Use the WPs and Docs window to create and maintain work product and document records for the open project, such as records for standards, procedures, guidelines, and templates.
To display the WPs and Docs window, do one of the following:
Refer to the following sections of this topic for information and links to concepts and tasks about working with work products and documents in the WPs and Docs window:
Working in the WPs and Docs window
When working in the WPs and Docs window, you can:
Tip
  • After opening the WPs and Docs window, the window remains open until you close all open projects or you close the window; if you open or navigate to another window without closing the WPs and Docs window, click the WPs and Docs tab to return to the window at any time.
  • When you add a document record, you have not added an actual document file; to add an actual file, you must associate a file with the document record on the Files tab of WP & Doc Details.
  • If you delete a document record, you have not deleted the actual document file.
  • When connected to a P6 EPPM database: You can not open, cut, copy, paste, or delete documents that have been added via a P6 installation with a configured content repository.
  • To expand or collapse individual elements of the work products and documents hierarchy, right-click in the WPs and Docs window and choose Expand All or Collapse All.
Work product and document concepts
The following concepts relate directly to working with work products and documents:
WPs and Docs tasks
You can perform all of the following tasks in the WPs and Docs window:
Related Topics
Project Toolbar
Edit Toolbar
Menu bar
Layout Toolbar
Move Toolbar
Bottom Layout Toolbar
Work Product and Document Details
Work Products and Documents
Work Breakdown Structure
Activities
View a project's document library
Specify work product and document location references
Remove work product and document assignments from the WPs and Docs window
Open a work product or document from the Work Products and Documents window
Identify a work product or document as a deliverable
Identify a document as a work product
Display work product and document details in the WPs and Docs window
Delete work product or document records
Assign work products and documents from the WPs and Docs window
Assign a document status or category
Add a work product or document record
Last Published Thursday, July 16, 2026
