Configuration metrics consist of the following categories.
The metrics in this category provide details about the charsets.
Default Collection Interval — Every 24 hours
Table 3-57 Charsets Information Metrics
| Metric | Description |
| Entity Type | Type of charset entity. |
| ID | Unique ID assigned to the entity. |
| Charset ID | Unique ID assigned to the charset. |
| Status | Status of the charset. |
| Charset Name | Name of the charset. |
| Description | A brief description of the charset. |
| Sort File | Name of the associated sort file. |
This section is a grouping of the following configuration parameters metric categories:
Backup/Recovery Configuration Parameters
Cache Manager Configuration Parameters
Component Integration Services Configuration Parameters
Configuration Options Configuration Parameters
DTM Administration Configuration Parameters
Diagnostics Configuration Parameters
Disk I/O Configuration Parameters
Error Log Configuration Parameters
Extended Stored Procedure Configuration Parameters
General Information Configuration Parameters
Java Services Configuration Parameters
Languages Configuration Parameters
Lock Manager Configuration Parameters
Memory Use Configuration Parameters
Meta-Data Caches Configuration Parameters
Monitoring Configuration Parameters
Network Communication Configuration Parameters
O/S Resources Configuration Parameters
Physical Memory Configuration Parameters
Physical Resources Configuration Parameters
Processors Configuration Parameters
Rep Agent Thread Administration Configuration Parameters
Security Related Configuration Parameters
SQL Server Administration Configuration Parameters
Unicode Configuration Parameters
User Environment Configuration Parameters
Maximum Number of Connections Configuration Parameters
The default collection interval for all these metric categories is — Every 24 hours
All these metric categories provide the following details:
Table 3-58 Configuration Parameters Metrics
| Parameter Name | Name of the configuration parameter. |
| Default Value | Default value assigned to this parameter. |
| Memory Used | Memory used by the parameter. |
| Config Value | Most recent value to which the configuration parameter has been set with sp_configure. |
| Run Value | Value being used by Adaptive Server. It changes after you modify a parameter's value with sp_configure and, for static parameters, after you restart Adaptive Server. |
| Unit | Unit of measurement. For example, bytes, number, and so on. |
| Type | Indicates whether the parameter is dynamic or static. For static The Adaptive Server needs to be restarted if it is a static parameter. and not if it is a dynamic parameter. |
The metrics in this category provide details about the database instances.
The default collection interval for all these metric categories is — Every 1 hour
Table 3-59 Database Instances Metrics
| Data Space Utilization (%) | Name of the configuration parameter. |
| Free Data Space (MB) | Default value assigned to this parameter. |
| Free Log Space (MB) | Memory used by the parameter. |
| Log Space Utilization (%) | Most recent value of the configuration parameter set by sp_configure. |
| Total Data Space (MB) | Value being used by Sybase Adaptive Server. It changes after you modify a parameter's value with sp_configure and for static parameters, after you restart Sybase Adaptive Server. |
| Total Log Space (MB) | Unit of measurement. For example, bytes, number, and so on. |
| Used Data Space(MB) | Indicates whether the parameter is dynamic or static. For static parameters, Sybase Adaptive Server needs to be restarted. For dynamic parameter, it need not be started. |
| Used Log Space (MB) | Used log space by the database instance. |
The metrics in this category provide details about the installed scripts.
Table 3-60 Installed Scripts Metrics
| Script Name | Name of the installed script. |
| Version | Version of the installed script. |
| Status | Current status of the script. |
The metrics in this category provide details about the version of Sybase ASE.
Table 3-61 Sybase ASE Version Metrics
| Version | Version of Sybase ASE. |
The metrics in this category provide details about the databases used.
Table 3-62 System Databases Metrics
| Database Name | Name of the database used. |
| Database Size | Size of the database used. |
| Owner Name | Name of the owner of the database. |
| Database ID | Unique ID of the database. |
| Date of Creation | Date when the database was created. |
| Status | Current status of the database. |
The metrics in this category provide details about the system listeners.
Table 3-63 System Listeners Metrics
| ASE Server Name and Port | Name of the ASE Server and the associated port. |
| Network Protocol | Network protocol used. |
