Diese Funktion gibt eine Liste der Assets zurück, die derzeit im Namen der Komponente in der Site gespeichert werden.
Parameter
| Name | Typ | Beschreibung |
Zeichenfolge |
Ruft den Listenersteller auf |
Funktion |
Callback-Funktion |
Verwendung
// get/set list of assets
SitesSDK.getProperty('componentAssets', callback);
SitesSDK.setProperty('componentAssets', [assets]);
// invoking list creator
// after calling this, the developer needs to call setProperty against
// 'componentAssets' to persist all currently used assets
// args:
// fileTypes - list of supported file types
// multiSelect - single or multiple file select
// returns a list of selected assets. If user cancels out of the picker,
// the callback is never called
SitesSDK.filePicker({options}, callback);
// example 'componentAssets' JSON returned:
'componentAssets': [{
'name': <nameOfAssetInContentFolder>, // this is used to uniquely and persistently identify the asset. It is typically prefixed by the ¿originalName¿ followed by a 16 digit string
'originalName': <originalName>, // name of the asset as selected from DOCS
'description': <description>, // description/other attributes that are available from DOCS
'url': <fully qualified url to the asset>
