Aggiornare il file settings.html per fornire un pannello di impostazioni che potrà essere utilizzato per impostare il testo del componente H1.
Per aggiungere un pannello di impostazioni per modificare il testo dell'intestazione, effettuare le operazioni riportate di seguito.
- Aggiornare il file
settings.html con il contenuto seguente:
<!DOCTYPE html>
<html lang="en">
<head>
<!-- only allow embedding of this iFrame in SCS -->
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>H1 Component</title>
<!-- include sample apps styling -->
<link href="/_sitescloud/renderer/app/sdk/css/app-styles.css" rel="stylesheet">
<!-- include supporting files -->
<script type="text/javascript" src="/_sitescloud/renderer/app/apps/js/knockout.min.js"></script>
<script type="text/javascript" src="/_sitescloud/renderer/app/apps/js/jquery.min.js"></script>
<!-- include the Sites SDK -->
<script type="text/javascript" src="/_sitescloud/renderer/app/sdk/js/sites.min.js"></script>
</head>
<body data-bind="visible: true" style="display:none; margin:0px; padding:0px;background:transparent;background-image:none;">
<div class="scs-component-settings">
<div>
<!-- Heading Text -->
<label id="headingTextLabel" for="headingText" class="settings-heading" data-bind="text: 'Heading Text'"></label>
<input id="headingText" data-bind="value: headingText" placeholder="Heading" class="settings-text-box">
</div>
</div>
<script type="text/javascript">
// define the viewModel object
var SettingsViewModel = function() {
var self = this;
// create the observables for passing data
self.headingText = ko.observable();
// create rest of viewModel
self.saveData = false;
// Get custom settings
SitesSDK.getProperty('customSettingsData', function(data) {
// update observable
self.headingText(data.headingText);
// now that viewModel is initialized and can start saving data
self.saveData = true;
// save whenever any updates occur, but don't save if data hasn't been loaded into the form yet
self.save = ko.computed(function() {
var saveconfig = {
'headingText': self.headingText()
// save data in page
if (self.saveData) {
SitesSDK.setProperty('customSettingsData', saveconfig);
}, self);
// apply the bindings
ko.applyBindings(new SettingsViewModel());
</script>
</body>
- Selezionare il componente in SiteBuilder e fare clic su Impostazioni.
Il pannello di impostazioni è di piccole dimensioni ed è impostato per essere incorporato nella parte superiore del pannello di impostazioni del componente. Cercare la sezione intitolata "Testo intestazione".
Per verificare che è possibile modificare il testo dell'intestazione (checkpoint 4):
Quando si modifica il testo dell'intestazione nel pannello delle impostazioni, il componente viene aggiornato per mostrare il nuovo testo.
