Questa funzione restituisce la lista degli asset memorizzati per conto del componente all'interno del sito.
Parametri
| Nome | Tipo | Descrizione |
Stringa |
Richiama l'autore della lista. |
Funzione |
Funzione di callback. |
Uso
// get/set list of assets
SitesSDK.getProperty('componentAssets', callback);
SitesSDK.setProperty('componentAssets', [assets]);
// invoking list creator
// after calling this, the developer needs to call setProperty against
// 'componentAssets' to persist all currently used assets
// args:
// fileTypes - list of supported file types
// multiSelect - single or multiple file select
// returns a list of selected assets. If user cancels out of the picker,
// the callback is never called
SitesSDK.filePicker({options}, callback);
// example 'componentAssets' JSON returned:
'componentAssets': [{
'name': <nameOfAssetInContentFolder>, // this is used to uniquely and persistently identify the asset. It is typically prefixed by the ¿originalName¿ followed by a 16 digit string
'originalName': <originalName>, // name of the asset as selected from DOCS
'description': <description>, // description/other attributes that are available from DOCS
'url': <fully qualified url to the asset>
