Replica degli utenti da un dominio di Identity a un altro
Utilizzare gli script in questa sezione per clonare gli utenti di un dominio di Identity in un altro dominio di Identity. L'utente che esegue questi script deve disporre dei ruoli Amministratore dominio di Identity e Amministratore servizi negli ambienti di origine e target.
Windows
Creare replicateusers.bat e replicateusers.ps1 copiando gli script in questa sezione.
  1. Creare replicateusers.ps1 copiando lo script riportato di seguito.
    # Replicate users script
    $inputproperties = ConvertFrom-StringData(Get-Content ./input.properties -raw)
    $epmusersource="$($inputproperties.epmusersource)"
    $epmpwdsource="$($inputproperties.epmpwdsource)"
    $epmurlsource="$($inputproperties.epmurlsource)"
    $epmidentitydomainsource="$($inputproperties.epmidentitydomainsource)"
    $epmusertarget="$($inputproperties.epmusertarget)"
    $epmpwdtarget="$($inputproperties.epmpwdtarget)"
    $epmurltarget="$($inputproperties.epmurltarget)"
    $epmidentitydomaintarget="$($inputproperties.epmidentitydomaintarget)"
    $proxyserverusername="$($inputproperties.proxyserverusername)"
    $proxyserverpassword="$($inputproperties.proxyserverpassword)"
    $proxyserverdomain="$($inputproperties.proxyserverdomain)"
    $userpassword="$($inputproperties.userpassword)"
    $resetpassword="$($inputproperties.resetpassword)"
    $emailtoaddress="$($inputproperties.emailtoaddress)"
    $roleassignmentreport="roleassignmentreport.csv"
    $usersreport="users.csv"
    echo "Replicate users script started"
    # delete existing reports
    $roleassignmentreportexists=Test-Path $roleassignmentreport
    if ($roleassignmentreportexists) {
        rm $roleassignmentreport 2>&1 | out-null
    $usersreportexists=Test-Path $usersreport
    if ($usersreportexists) {
        rm $usersreport 2>&1 | out-null
    # epmautomate login Source App as an IDM Admin
    echo "Logging into source application at ${epmurlsource}"
    epmautomate login ${epmusersource} ${epmpwdsource} ${epmurlsource} ${epmidentitydomainsource} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
    echo "Creating role assignment report: ${roleassignmentreport}"
    epmautomate roleAssignmentReport ${roleassignmentreport}
    if (${emailtoaddress} -match "@") {
        epmautomate.bat sendMail $emailtoaddress "Role assignment report" Body="Role assignment report is attached." Attachments=$roleassignmentreport}
    echo "Downloading role assignment report"
    epmautomate downloadfile ${roleassignmentreport}
    epmautomate deletefile ${roleassignmentreport}
    epmautomate logout
    # Create users report
    Get-Content ${roleassignmentreport} | ForEach-Object {
        $user=$_.split(',')[0]
        $firstname=$_.split(',')[1]
        $lastname=$_.split(',')[2]
        $email=$_.split(',')[3]
        if ($firstname -eq "First Name") {
            return
        } else {
            echo "${firstname},${lastname},${email},${user}" >> ${usersreport}
    Get-Content -Path "${usersreport}" | Sort-Object -Unique > "${usersreport}.tmp"
    mv -Force "${usersreport}.tmp" "${usersreport}"
    $userheader="First Name,Last Name,Email,User Login"
    "${userheader}`r`n" + (Get-Content $usersreport -Raw) | Set-Content $usersreport
    # epmautomate login Target App as an IDM Admin
    echo "Logging into target application at ${epmurltarget}"
    epmautomate login ${epmusertarget} ${epmpwdtarget} ${epmurltarget} ${epmidentitydomaintarget} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
    epmautomate deletefile ${usersreport} | Out-Null
    echo "Uploading file ${usersreport}"
    epmautomate uploadfile ${usersreport}
    echo "Adding users"
    epmautomate addUsers ${usersreport} userPassword=${userpassword} resetPassword=${resetpassword}
    epmautomate logout
    rm deletefile*.log | Out-Null
    echo "Replicate users script completed"
  2. Creare il file input.properties copiando lo script riportato di seguito.
    epmusersource=EPM USER FOR SOURCE ENVIRONMENT
    epmpwdsource=EPM PASSWORD FILE FOR SOURCE ENVIRONMENT
    epmurlsource=EPM URL FOR SOURCE ENVIRONMENT
    epmidentitydomainsource=EPM IDENTITY DOMAIN FOR SOURCE ENVIRONMENT
    epmusertarget=EPM USER FOR TARGET ENVIRONMENT
    epmpwdtarget=EPM PASSWORD FILE FOR TARGET ENVIRONMENT
    epmurltarget=EPM URL FOR TARGET ENVIRONMENT
    epmidentitydomaintarget=EPM IDENTITY DOMAIN FOR TARGET ENVIRONMENT
    proxyserverusername=PROXY SERVER USER NAME
    proxyserverpassword=PROXY SERVER PASSWORD FILE
    proxyserverdomain=PROXY SERVER DOMAIN
    userpassword=DEFAULT PASSWORD FOR REPLICATED USERS
    resetpassword=false
    emailtoaddress=EMAIL_TO_ADDRESS
  3. Aggiornare input.properties. Fare riferimento alla tabella riportata di seguito per le informazioni sui valori da specificare.
    Parametro Descrizione
    epmusersource Nome utente di un utente con i ruoli Amministratore dominio di Identity e Amministratore servizi nell'ambiente di origine.
    Esempi:
    Windows: set epmusersource="jDoe"
    Linux/UNIX: epmusersource="jDoe"
    epmpwdsource La password dell'utente o il percorso assoluto del file delle password cifrate.
    Esempi:
    Windows: set epmpwdsource="Example"
    Linux/UNIX: epmpwdsource="Example"
    epmurlsource URL dell'ambiente da cui devono essere copiati gli utenti.
    Esempi:
    Windows: set epmurlsource="https://example.oraclecloud.com"
    Linux/UNIX: epmurlsource="https://example.oraclecloud.com"
    epmidentitydomainsource Nome del dominio di Identity utilizzato dall'ambiente di origine.
    Esempi:
    Windows: set epmidentitydomainsource="example_source_dom"
    Linux/UNIX: epmidentitydomainsource="example_source_dom"
    epmusertarget Nome utente di un utente con i ruoli Amministratore dominio di Identity e Amministratore servizi nell'ambiente target.
    Esempi:
    Windows: set epmusertarget="John.Doe"
    Linux/UNIX: set epmusertarget="John.Doe"
    epmpwdtarget La password dell'utente o il percorso assoluto del file delle password cifrate.
    Esempi:
    Windows: set epmpwdtarget="Example1"
    Linux/UNIX: epmpwdtarget="Example1"
    epmurltarget URL dell'ambiente in cui devono essere creati gli utenti.
    Esempi:
    Windows: set epmurltarget="https://example.oraclecloud.com"
    Linux/UNIX: epmurltarget="https://example.oraclecloud.com"
    epmidentitydomaintarget Nome del dominio di Identity utilizzato dall'ambiente target.
    Esempi:
    Windows: set epmidentitydomaintarget="example_source_dom"
    Linux/UNIX: epmidentitydomaintarget="example_target_dom"
    proxyserverusername Il nome utente per l'autenticazione di una sessione sicura con il server proxy che controlla l'accesso a Internet. Eliminare tutte le occorrenze di questa proprietà, se non utilizzate.
    Esempi:
    Windows: set proxyserverusername="Example"
    Linux/UNIX: proxyserverusername="Example"
    proxyserverpassword La password per autenticare l'utente con il server proxy. Eliminare tutte le occorrenze di questa proprietà, se non utilizzate.
    Esempi:
    Windows: set proxyserverpassword="examplePwd"
    Linux/UNIX: proxyserverpassword="examplePwd"
    proxyserverdomain Il nome del dominio definito per il server proxy. Eliminare tutte le occorrenze di questa proprietà, se non utilizzate.
    Esempi:
    Windows: set proxyserverdomain="exampleDom"
    Linux/UNIX: proxyserverdomain="exampleDom"
    emailtoaddress (Facoltativo) Indirizzo e-mail a cui deve essere inviato il report assegnazioni ruoli. Il report viene inviato via e-mail solo se viene specificato questo valore.
    Esempio: emailtoaddress=john.doe@example.com
Linux/UNIX
  1. Creare replicateusers.sh copiando lo script riportato di seguito.
    #!/bin/sh
    . ./input.properties
    paramrequiredmessage='Syntax: replicateusers.sh
    export JAVA_HOME=${javahome}
    ${epmautomatescript} login ${epmusersource} ${epmpwdsource} ${epmurlsource} ${epmidentitydomainsource} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
    ${epmautomatescript} roleAssignmentReport ${roleassignmentreport}
    if [[ "${emailtoaddress}" == *"@"* ]]
    then
        ${epmautomatescript} sendMail $emailtoaddress "Role assignment report" Body="Role assignment report is attached." Attachments=$roleassignmentreport
    fi
    ${epmautomatescript} downloadfile ${roleassignmentreport}
    ${epmautomatescript} deletefile ${roleassignmentreport}
    ${epmautomatescript} logout
    awk -F, '{print $2","$3","$4","$1}' ${roleassignmentreport} | (read -r; printf "%s\n" "$REPLY"; sort -u) > ${usersreport}
    ${epmautomatescript} login ${epmusertarget} ${epmpwdtarget} ${epmurltarget} ${epmidentitydomaintarget} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
    ${epmautomatescript} deletefile ${usersreport} > /dev/null 2>&1
    ${epmautomatescript} uploadfile ${usersreport}
    echo "Adding users"
    ${epmautomatescript} addUsers ${usersreport} userPassword=${userpassword} resetPassword=${resetpassword}
    rm deletefile*.log > /dev/null 2>&1
    javahome=JAVA HOME
    epmautomatescript=EPM AUTOMATE SCRIPT LOCATION
    resetpassword=false
  3. Aggiornare input.properties. Fare riferimento alla Tabella 3-* per informazioni sui valori da specificare. Inoltre, è necessario specificare i valori per le proprietà riportate di seguito.
    • javahome: il percorso assoluto alla directory dove è installato Java.
    • epmautomatescript: posizione di epmautomatescript.sh; ad esempio, epmautomatescript="/home/user1/epmautomate/bin/epmautomate.sh"
