次に、ジョブを作成するユーザー要求の例をいくつか示します。
Create job config 'April 2025 budget' for calculate model '20 Actuals Allocation Process' povs FY25:Apr:Budget:Working pov delimiter ':' comment 'Calculating April 2025 budget'
Create job config 'My Allocation Job' for calculate model '10 Actuals Allocation Process' povs FY25:Apr:Budget:Working pov delimiter ':' clear Calculated data true execute calculations true capture debug scripts true capture diagnostic data false optimize for reporting true
