En kompilator for sideoppsett er en JavaScript-modul for NodeJS (CommonJS) som kompilerer det tilsvarende sideoppsettet.
Kompilatoren for sideoppsett for et bestemt sideoppsett defineres av navntilknytningen med en utvidelse av typen -compile.js:
src
themes
<yourTheme>
layouts
<yourPageLayout>.html<yourPageLayout>-compile.jsHvis det ikke finnes noen -compile.js for et sideoppsett, blir det ikke brukt noen egendefinert kompilering.
En kompilator for sideoppsett må implementere et compile()-grensesnitt, som returnerer et løfte, for eksempel about-compile.js:
var mustache = require('mustache');
var PageCompiler = function () {};
PageCompiler.prototype.compile = function (args) {
var self = this,
layoutMarkup = args.layoutMarkup;
self.SCSCompileAPI = args.SCSCompileAPI;
return new Promise function (resolve, reject) {
var compiledPage = layoutMarkup,
id = self.SCSCompileAPI.navigationRoot;
// page is compiled so there is no FOUC, can remove the opacity
workaround
compiledPage = compiledPage.replace('opacity: 0;', 'opacity: 1;');
// remove the dynamic menu creation, we'll be compiling it here
compiledPage = compiledPage.replace('<script
src="_scs_theme_root_/assets/js/topnav.js"></script>', '');
// add link to Home page. . .
var homePageURL = (self.SCSCompileAPI.getPageLinkData(id) ||
{}).href;
if (homePageURL) {
compiledPage = compiledPage.replace('class="navbar-brand"
href="#"', 'class="navbar-brand" href="' + homePageURL + '"');
// build the menu and add it to the page
var navMenu = self.createNavMenu();
compiledPage = compiledPage.replace('<!-- navigation menu goes in
here -->', navMenu);
// return the compiled page
resolve(compiledPage);
// Create the navigation menu that was previously dynamically generated on
each page
PageCompiler.prototype.createNavMenu = function () {
module.exports = new PageCompiler();
