A fim de manter o ambiente de standby atualizado em relação ao ambiente principal, use estes scripts para clonar o ambiente principal do Oracle Fusion Cloud Enterprise Performance Management no ambiente de standby assim que a manutenção diária do ambiente principal terminar.
Estes scripts personalizados identificam se a manutenção diária agendada foi concluída e clonam o ambiente.
Script do Windows
Crie odailyclone.ps1 copiando o seguinte script PowerShell.
# Clone Environment script
# Update the following parameters
$users_and_predefined_roles="false"
$daily_maintenance_start_time="true"
$data_management="true"
$app_audit="true"
$job_console="true"
$stored_snapshots_and_files="false"
$source_username=$args[0]
$source_password=$args[1]
$source_url=$args[2]
$target_username=$args[3]
$target_password=$args[4]
$target_url=$args[5]
if ($($args.count) -ne 6) {
echo "Usage: ./dailyclone.ps1 <SOURCE USERNAME> <SOURCE PASSWORD> <SOURCE URL> <TARGET USERNAME> <TARGET PASSWORD> <TARGET URL>"
exit 1
$amw_time=""
function getDailyMaintenanceStartTime {
$amwstring=$(epmautomate.bat getDailyMaintenanceStartTime)
$elements=$amwstring.split(' ')
$amwtime=$elements[0]
return $amwtime
function goToSleep ($amw_time){
$current_mdy=Get-Date -AsUTC -UFormat "%m/%d/%Y"
$current_date_time=Get-Date -AsUTC -UFormat "%m/%d/%Y %H:%M:%S"
$current_epoch=Get-Date -Date $current_date_time -UFormat "%s"
$target_date_time=[DateTime]"${current_mdy} ${amw_time}"
$target_epoch=Get-Date -Date $target_date_time -UFormat "%s"
$sleep_seconds=$target_epoch - $current_epoch
# Today's AMW start time has already passed, so add 24 hours to sleep_seconds
if ($sleep_seconds -lt 0) {
$sleep_seconds=$sleep_seconds + 86400
$sleep_ts=New-TimeSpan -Seconds ${sleep_seconds}
$sleep_hms="${sleep_ts}" -replace '^\d+?\.'
echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}."
Start-Sleep -Seconds $sleep_seconds
function deleteArtifactSnapshotIfExists {
if (artifactSnapshotExists) {
$command_del=$(epmautomate.bat deletefile "Artifact Snapshot")
function artifactSnapshotExists {
$filelist=$(epmautomate.bat listfiles)
if ("$filelist".contains("Artifact Snapshot")) {
return $true
else
return $false
function cloneEnvironment {
echo "Checking to see if daily maintenance processing has completed ..."
while ($true) {
echo "Daily maintenance processing has completed ..."
break
} else {
echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..."
Start-Sleep -Seconds 30
echo "Encrypting target password ..."
epmautomate.bat encrypt "${target_password}" "oracleKey" "target_password.epw"
echo "Cloning environment ..."
epmautomate.bat cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}"
echo "Beginning clone environment script."
echo "Logging into server ..."
epmautomate.bat login ${source_username} ${source_password} ${source_url}
$amwtime=getDailyMaintenanceStartTime
goToSleep ($amwtime)
cloneEnvironment
echo "Logging out of server ..."
epmautomate.bat logout
echo "Clone environment script processing has completed."
Script de Linux/UNIX
Crie odailyclone.sh copiando o seguinte script.
#!/bin/bash # Update the following parameters # ------------------------------- epmautomatescript="LOCATION_EPM_AUTOMATE_EXECUTABLE" javahome="LOCATION_JAVA_HOME" users_and_predefined_roles="false" data_management="true" app_audit="true" job_console="true" stored_snapshots_and_files="false" daily_maintenance_start_time="true" # ------------------------------- source_username="$1" source_password="$2" source_url="$3" target_username="$4" target_password="$5" target_url="$6" export JAVA_HOME=${javahome} if [ "$#" -ne 6 ]; then echo "Usage: ./dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL" exit 1 fi amw_time="" getDailyMaintenanceStartTime() { amw_time=$(${epmautomatescript} getDailyMaintenanceStartTime | cut -d' ' -f1) } goToSleep() { current_mdy=$(date -u +%m/%d/%Y) current_date_time=$(date -u) current_epoch=$(date +%s) target_epoch=$(date -d "${current_mdy} ${amw_time}" +%s) sleep_seconds=$(($target_epoch - $current_epoch)) # Today's AMW start time has already passed, so add 24 hours to sleep_seconds if [[ ${sleep_seconds} -lt 0 ]] then sleep_seconds=$((sleep_seconds + 86400)) fi sleep_hms=$(date -d@${sleep_seconds} -u +%H:%M:%S) echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}." sleep $sleep_seconds } deleteArtifactSnapshotIfExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then command_del=$(${epmautomatescript} deletefile "Artifact Snapshot") fi } artifactSnapshotExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then found=0 else found=1 fi echo ${found} } cloneEnvironment() { local found=1 while true do found=$(artifactSnapshotExists) if [[ ${found} -eq 0 ]] then echo "Daily maintenance processing has completed ..." break else echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..." sleep 30 fi done echo "Encrypting target password ..." ${epmautomatescript} encrypt "${target_password}" "oracleKey" "target_password.epw" echo "Cloning environment ..." ${epmautomatescript} cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}" } echo "Beginning clone environment script." echo "Logging into server ..." ${epmautomatescript} login ${source_username} ${source_password} ${source_url} getDailyMaintenanceStartTime goToSleep deleteArtifactSnapshotIfExists cloneEnvironment echo "Logging out of server ..." ${epmautomatescript} logout echo "Clone environment script processing has completed."
Script do Groovy
Crie o script groovydailyclone copiando o seguinte código.
// Clone Environment script // Update the following parameters String source_username="USERNAME" String source_password="PASSWORD!" String source_url="URL OF THE SOURCE ENVIRONMENT" String target_username="USERNAME" String target_password="PASSWORD" String target_url="URL OF THE TARGET ENVIRONMENT" String snapshot_name="Artifact Snapshot" // ------------------------------- // Do not update the following parameters String users_and_predefined_roles="false" String data_management="true" String app_audit="true" String job_console="true" String stored_snapshots_and_files="false" String daily_maintenance_start_time="true" // ------------------------------- def LogMessage(String message) { def date = new Date() def sdf = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") println('[' + sdf.format(date) + '] ' + message); } def LogOperationStatus(EpmAutomateStatus opstatus) { def returncode = opstatus.getStatus() if (returncode != 0){ LogMessage(opstatus.getOutput()) } LogMessage('return code: ' + returncode) } def getDailyMaintenanceStartTime(EpmAutomate automate) { LogMessage("Operation: getDailyMaintenanceStartTime") EpmAutomateStatus amwtimestatus = automate.execute('getDailyMaintenanceStartTime') LogOperationStatus(amwtimestatus) def amwstring=(amwtimestatus.getOutput()) def elements=amwstring.split(' ') def amwtime=elements[0] return amwtime } def goToSleep(String amw_time){ def date = new Date() def current_mdy = new SimpleDateFormat("MM/dd/yyyy") def current_date_time = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") float current_epoch = date.getTime() / 1000 def pattern = "MM/dd/yyyy HH:mm:ss" def input = current_mdy.format(date) + " " + amw_time + ":00" def target_date_time = Date.parse(pattern, input) float target_epoch = target_date_time.getTime() / 1000 int sleep_seconds = Math.round(target_epoch - current_epoch) //Today's AMW start time has already passed, so add 24 hours to sleep_seconds if (sleep_seconds < 0) { sleep_seconds = sleep_seconds + 86400 } def sleep_milliseconds = sleep_seconds * 1000 LogMessage("Current time is " + current_date_time.format(date) + ". Sleeping until daily maintenance start time of " + amw_time + ":00.") sleep(sleep_milliseconds) } boolean artifactSnapshotExists(EpmAutomate automate,String snapshot_name) { LogMessage("Operation: listfiles") EpmAutomateStatus listfilesstatus = automate.execute('listfiles') String filelist=(listfilesstatus.getItemsList()) LogOperationStatus(listfilesstatus) if (filelist.contains(snapshot_name)) { return true } else { return false } } def deleteArtifactSnapshotIfExists(EpmAutomate automate,String snapshot_name){ if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Operation: deletefile " + snapshot_name) EpmAutomateStatus deletefilestatus = automate.execute('deletefile',snapshot_name) LogOperationStatus(deletefilestatus) } } def waitForDailyMaintenanceToComplete(EpmAutomate automate,String snapshot_name) { LogMessage("Checking to see if daily maintenance processing has completed ...") while (true) { if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Daily maintenance processing has completed ...") break } else { LogMessage("Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ...") sleep(30000) } } } LogMessage("Clone environment script processing beginning ...") EpmAutomate automate = getEpmAutomate() LogMessage("Operation: login " + source_username + " " + source_password + " " + source_url) EpmAutomateStatus status = automate.execute('login',source_username,source_password,source_url) LogOperationStatus(status) String amwtime = getDailyMaintenanceStartTime(automate) goToSleep (amwtime) deleteArtifactSnapshotIfExists(automate,snapshot_name) waitForDailyMaintenanceToComplete(automate,snapshot_name) LogMessage("Operation: encrypt " + target_password + " oracleKey target_password.epw") status = automate.execute('encrypt',target_password,'oracleKey','target_password.epw') LogOperationStatus(status) LogMessage("Operation: cloneEnvironment " + target_username + " target_password.epw " + target_url + " SnapshotName=" + snapshot_name + " UsersAndPreDefinedRoles=" + users_and_predefined_roles + " DataManagement=" + data_management + " appAudit=" + app_audit + " jobConsole=" + job_console + " storedSnapshotsAndFiles=" + stored_snapshots_and_files + " dailyMaintenanceStartTime=" + daily_maintenance_start_time) EpmAutomateStatus cloneenvironmentstatus = automate.execute('cloneEnvironment',target_username,"target_password.epw",target_url,"SnapshotName=" + snapshot_name,"UsersAndPreDefinedRoles=" + users_and_predefined_roles,"DataManagement=" + data_management,"appAudit=" + app_audit,"jobConsole=" + job_console,"storedSnapshotsAndFiles=" + stored_snapshots_and_files,"dailyMaintenanceStartTime=" + daily_maintenance_start_time) LogOperationStatus(cloneenvironmentstatus) LogMessage("Operation: logout ") status = automate.execute('logout') LogOperationStatus(status) LogMessage ("Clone environment script processing has completed.")
Execução do Script
dailyclone.ps1, o dailyclone.sh ou o script groovy dailyclone copiando um script de uma das seções anteriores.Atualização do arquivo dailyclone.sh:
epmautomatescript com o local do executável do EPM Automate. Exemplo: epmautomatescript="/home/utils/EPMAutomate/bin/epmautomate.sh"javahome com o diretório onde o JDK usado pelo EPM Automate está instalado. Por exemplo: "/home/user1/jdk_17.0.12"dailyclone.ps1 e dailyclone.sh:
users_and_predefined_roles: Defina esse valor como true para clonar usuários e suas respectivas atribuições de função de aplicativo (os grupos do EPM são sempre clonados).data_management: Defina esse valor como false para não clonar os registros de Integração de Dados. Observe que os registros de Integração de Dados só poderão ser clonados se os ambientes de origem e de destino estiverem na mesma atualização mensal ou se o ambiente de destino estiver em uma atualização mais nova que a do ambiente de origem. Por exemplo, você só pode clonar registros do Data Management 22.01 para um ambiente com a atualização 22.01 ou para um ambiente com a atualização 22.02.
Ignorado para ambientes do Narrative Reporting e do Oracle Enterprise Data Management Cloud.
app_audit: Defina esse valor como false se não quiser clonar os dados de auditoria do aplicativo para os aplicativos do Planning, FreeForm e Enterprise Profitability and Cost Management.
As informações de auditoria do Financial Consolidation and Close e do Tax Reporting sempre são clonadas.
job_console: Defina esse valor como false se não quiser clonar os dados do console de jobs.stored_snapshots_and_files: Defina esse valor como true se quiser clonar o conteúdo das pastas de nível superior na caixa de entrada e na caixa de saída do ambiente de origem (as subpastas nunca são clonadas).daily_maintenance_start_time: Defina esse valor como false se não quiser redefinir o horário de início da manutenção do ambiente de destino clonado como o horário do ambiente de origem.dailyclone:
source_username é o nome de usuário de um Administrador de Serviço. A função Administrador de Domínio de Identidades é necessária para clonar usuários e funções de aplicativo.source_password é a senha do usuário identificado por SOURCE_USERNAME.source_url é o URL do ambiente a ser clonado.target_username é o nome de usuário de um Administrador de Serviço. A função Administrador de Domínio de Identidades é necessária para clonar usuários e funções de aplicativo.target_password é a senha do usuário identificado por TARGET_USERNAME.target_URL é o URL do ambiente de destino.dailyclone.ps1, o dailyclone.sh ou o script groovy dailyclone:
Windows
dailyclone.ps1 está armazenado../dailyclone.ps1 SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Consulte a tabela a seguir para ver a descrição desses valores.Table 3-7 Descrição dos Parâmetros
| Parâmetro | Descrição |
SOURCE_USERNAME |
Nome de usuário de um Administrador de Serviço. Além disso, esse usuário deve ter a função Administrador de Domínio de Identidades para clonar usuários e funções de aplicativo. |
SOURCE_PASSWORD |
A senha do usuário identificado por SOURCE_USERNAME. |
SOURCE_URL |
O URL do ambiente a ser clonado. |
TARGET_USERNAME |
O nome de usuário de um Administrador de Serviço no ambiente de destino. Além disso, esse usuário deve ter a função Administrador de Domínio de Identidades para clonar usuários e funções de aplicativo. |
TARGET_PASSWORD |
A senha do usuário identificado por TARGET_USERNAME. |
TARGET_URL |
O URL do ambiente de destino. |
dailyclone.sh está armazenado../dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Consulte a tabela acima para ver a descrição desses valores.
