页布局编译器
页布局编译器是用于编译相应页布局的 NodeJS (CommonJS) JavaScript 模块。
特定页布局的页布局编译器通过具有 -compile.js 扩展的名称关联进行定义:
  • src
    • themes
      • <yourTheme>
        • layouts
          • <yourPageLayout>.html
          • <yourPageLayout>-compile.js
如果页布局不存在 -compile.js,则不应用定制编译。
页布局编译器需要实施 compile() 接口,其返回 Promise;例如 about-compile.js:
var mustache = require('mustache');
var PageCompiler = function () {};
PageCompiler.prototype.compile = function (args) {
    var self = this,
        layoutMarkup = args.layoutMarkup;
    self.SCSCompileAPI = args.SCSCompileAPI;
    return new Promise function (resolve, reject) {
        var compiledPage = layoutMarkup,
            id = self.SCSCompileAPI.navigationRoot;
        // page is compiled so there is no FOUC, can remove the opacity
workaround
        compiledPage = compiledPage.replace('opacity: 0;', 'opacity: 1;');
        // remove the dynamic menu creation, we'll be compiling it here
        compiledPage = compiledPage.replace('<script
src="_scs_theme_root_/assets/js/topnav.js"></script>', '');
        // add link to Home page. . .
        var homePageURL = (self.SCSCompileAPI.getPageLinkData(id) ||
{}).href;
        if (homePageURL) {
            compiledPage = compiledPage.replace('class="navbar-brand"
href="#"', 'class="navbar-brand" href="' + homePageURL + '"');
        // build the menu and add it to the page
        var navMenu = self.createNavMenu();
        compiledPage = compiledPage.replace('<!-- navigation menu goes in
here -->', navMenu);
        // return the compiled page
        resolve(compiledPage);
// Create the navigation menu that was previously dynamically generated on
each page
PageCompiler.prototype.createNavMenu = function () {
module.exports = new PageCompiler();
