使用本节中的 PowerShell 脚本可自动创建用于详述环境中角色分配和角色撤消的审核报表。
通过复制以下脚本来创建 AuditReportRoleAssignment.bat。此包装器批处理脚本调用 PowerShell 脚本 AuditReportRoleAssignment.ps1,此方案后面提供了其源代码。
注:
AuditReportRoleAssignment.bat 的输入参数为 username、password_file 和 service_url。脚本:AuditReportRoleAssignment.bat
@echo off set paramRequiredMessage=Syntax: AuditReportRoleAssignment.bat USERNAME PASSWORD_FILE URL if "%~1" == "" ( echo User Name is missing. echo %paramRequiredMessage% exit /b 1 ) if "%~2" == "" ( echo Password_File is missing. echo %paramRequiredMessage% exit /b 1 ) if "%~3" == "" ( echo URL is missing. echo %paramRequiredMessage% exit /b 1 ) PowerShell.exe -File AuditReportRoleAssignment.ps1 %*
脚本:AuditReportRoleAssignment.ps1
# EPM Automate Role Assignment Audit Report Script
$username=$args[0]
$password=$args[1]
$url=$args[2]
# Generic variables
$date=$(get-date -f dd_MM_yy_HH_mm_ss)
$datedefaultformat=$(get-date)
$logdir="./logs/"
$logfile="$logdir/epmautomate-provisionauditreport-" + $date + ".log"
$reportdir="./reports/"
$provisionreport="provreport-audittest-" + $date + ".csv"
$provisionreporttemp="./provreport-audittest-temp.csv"
$provisionreportunique="./provreport-audittest-unique.csv"
$provisionreportbaselineunique="./provreport-audittest-baseline-unique.csv"
function EchoAndLogMessage
$message=$args[0]
echo "$message"
echo "$message" >> $logfile
function Init
$logdirexists=Test-Path $logdir
if (!($logdirexists)) {
mkdir $logdir 2>&1 | out-null
$logfileexists=Test-Path $logfile
if ($logfileexists) {
rm $logfile 2>&1 | out-null
$reportdirexists=Test-Path $reportdir
if (!($reportdirexists)) {
mkdir $reportdir 2>&1 | out-null
function PostProcess
rm $provisionreporttemp
mv -Force $provisionreportunique $provisionreportbaselineunique
function ProcessCommand
$op=$args
echo "EPM Automate operation: epmautomate.bat $op" >> $logfile
epmautomate.bat $op >> $logfile 2>&1
if ($LASTEXITCODE -ne 0) {
echo "EPM Automate operation failed: epmautomate.bat $op. See $logfile for details."
exit
function RunEpmAutomateCommands
EchoAndLogMessage "Running EPM Automate commands to generate the audit report."
ProcessCommand login $username $password $url
ProcessCommand provisionreport $provisionreport
ProcessCommand downloadfile $provisionreport
ProcessCommand deletefile $provisionreport
ProcessCommand logout
function CreateProvisionReportTempFile
# Loop through iteration csv file and parse
Get-Content $provisionreport | ForEach-Object {
$elements=$_.split(',')
echo "$($elements[0]),$($elements[2])" >> $provisionreporttemp
function CreateUniqueElementsFile
gc $provisionreporttemp | sort | get-unique > $provisionreportunique
function CheckBaselineAndCreateAuditReport
$provisionreportbaselineuniqueexists=Test-Path $provisionreportbaselineunique
if (!($provisionreportbaselineuniqueexists)) {
EchoAndLogMessage "Could not find a baseline audit report to compare with. Audit report will be created next time you run test."
} else {
CreateAuditReport
function CreateAuditReport
$auditreport=$reportdir + "auditreport-"+ $date + ".txt"
$additions = @()
$deletions = @()
EchoAndLogMessage "Comparing previous audit report with the current one."
$compare=compare-object (get-content $provisionreportunique) (get-content $provisionreportbaselineunique)
$compare | foreach {
if ($_.sideindicator -eq '<=')
$additions += $_.inputobject
} elseif ($_.sideindicator -eq '=>') {
$deletions += $_.inputobject
echo "Provisioning Audit Report for $datedefaultformat" > $auditreport
echo "------------------------------------------------" >> $auditreport
if ($additions.count -ne 0)
echo " " >> $auditreport
echo "Additions:" >> $auditreport
foreach($element in $additions) { echo "$element" >> $auditreport }
if ($deletions.count -ne 0)
echo "Deletions:" >> $auditreport
foreach($element in $deletions) { echo "$element" >> $auditreport }
if (($additions.count -eq 0) -and ($deletions.count -eq 0))
echo "No changes from last audit report." >> $auditreport
EchoAndLogMessage "Role audit report generated: $auditreport."
Init
EchoAndLogMessage "Starting EPMAutomate role audit report generation"
PostProcess
EchoAndLogMessage "EPMAutomate role audit report completed"
