自動從聚總儲存立方體匯出大量儲存格
使用本節中的 PowerShell 或 Bash 指令碼,從聚總儲存 (ASO) 立方體中匯出大量儲存格。
由於 Oracle Essbase QUERYRESULTLIMIT 所規定的限制,因此無法從使用者介面匯出大量資料。本節中提供的 PowerShell 指令碼會將匯出作業分割成指定數量的工作、執行每個工作、下載所匯出的資料,然後將匯出檔案串接成一個匯出檔案,確保只有一個標頭存在。
註:
這些指令碼會執行匯出資料類型的現有工作。如需有關建立工作的詳細指示,請參閱管理 Planning 中的管理工作。
PowerShell 指令碼
$user = '<USERNAME>'
$pass = '<PASSWORD>'
$serverURL = '<URL>'
$applicationName = '<APPLICATIONNAME>'
$cubeName = '<CUBENAME>'
$splitDimension = '<DIMENSION_TO_SPLIT_THE_EXPORT>'
$topLevelMemberForExport = '<TOP_MEMBER_FOR_EXPORT>'
$exportJobName = '<EXPORT_JOB_NAME>'
$exportFilePrefix = '<PREFIX_FOR_EXPORT_FILE>'
$columnMembers = '<MEMBERS_ON_COLUMNS>'
$povMembers = '<POV_MEMBERS>'
$numberOfExportFiles = <NUMBER_OF_FILES_TO_SPLIT_THE_EXPORT>
$memberArray = @()
$exportFileArray = @()
function getLevel0 ($parent) {
    $parent.children.ForEach({
        if ( $_.children.count -eq 0 ) {
            $script:memberArray += $_.name
        getLevel0($_)
function findMember ($tree, $memberName) {
    $subtree = ""
    if ($tree.name -eq $memberName){
        return $tree
    } else {
        $tree.children.ForEach({
            #Write-Host $_.name
            if ($subtree -eq ""){ $subtree = findMember $_ $memberName}
        return $subtree
#putting together base64 encoded authentication header based un user and password
$encodedCredentials = [Convert]::ToBase64String([System.Text.Encoding]::ASCII.GetBytes($($user) + ":" + $($pass)))
$headers = @{ Authorization = "Basic $encodedCredentials" }
#test login
$testRequest = $serverURL + '/HyperionPlanning/rest/v3/applications'
try {
    $response = Invoke-RestMethod -Uri $testRequest -Method Get -Headers $headers -UseBasicParsing
catch {
    Write-Host $_
    return
#retrieve dimension hierarchy from application
Write-Host "Retrieving member list for split dimension " $splitDimension
$request = $serverURL + '/HyperionPlanning/rest/v3/internal/applications/' + $applicationName + '/plantypes/' + $cubeName + '/dimensions/' + $splitDimension
try {
    $response = Invoke-RestMethod -Uri $request -Method Get -Headers $headers -UseBasicParsing
catch {
    Write-Host $_
    return
Write-Host $splitDimension " member list retrieved"
#search for the top of the export hierarchy
Write-Host "Searching for member " $topLevelMemberForExport " in hierarchy"
$member = findMember $response $topLevelMemberForExport
if ( $member.name -ne $topLevelMemberForExport ) {
    Write-Host $topLevelMemberForExport " not found in hierarchy, exiting ..."
    return 128
Write-Host "Found member " $topLevelMemberForExport " in hierarchy"
#retrieve level 0 memebers in export hierarchy
Write-Host "Retrieving Level 0 members for hierarchy"
getLevel0($member)
if ( $memberArray.Length -eq 0 ) {
    Write-Host "no level 0 members found in hierarchy, exiting ..."
    return 128
Write-Host $memberArray.Length " Level 0 members for export hierarchy retrieved"
$request = $serverURL + '/HyperionPlanning/rest/v3/applications/' + $applicationName + '/jobs'
#splitting member list into the number of export files
$numberOfEntitiesPerFile = [math]::truncate($memberArray.Length / $numberOfExportFiles)
for ($i = 1; $i -le $numberOfExportFiles; $i++) {
    $memberList = ""
    $firstMember = ($i - 1) * $numberOfEntitiesPerFile
    if ($i -lt $numberOfExportFiles) {
        $lastMember = $i * $numberOfEntitiesPerFile
    } else {
        $lastMember = $i * $numberOfEntitiesPerFile + $memberArray.Length % $numberOfExportFiles
    for ($j = $firstMember; $j -lt $lastMember; $j++) {
        $memberList += $memberArray[$j]
        if ($j -lt $lastMember - 1) {$memberList += ","} #avoid adding a comma (,) after the last member of each set
    $jobDetails='
    "jobType":"EXPORT_DATA","jobName":"' + $exportJobName + '",
    "parameters":{
                  "exportFileName":"Export-' + $i + '.zip",
                  "rowMembers":"' +  $memberList + '",
                  "columnMembers":"' + $columnMembers + '",
                "povMembers":"' + $povMembers + '"
    #start export job
    try{
        $response = Invoke-RestMethod -Uri $request -Method Post -Headers $headers -Body $jobDetails -ContentType "application/json"}
    catch {
        Write-Host $_
        return
    Write-Host "Started export job " $i " out of " $numberOfExportFiles
    #checking job status, continue once jos is completed
    $statusRequest = $serverURL + '/HyperionPlanning/rest/v3/applications/' + $applicationName + '/jobs/' + $response.jobId
    $statusResponse = Invoke-RestMethod -Uri $statusRequest -Method Get -Headers $headers -UseBasicParsing
    while ( $statusResponse.descriptiveStatus -eq "Processing" ) {
        Write-Host $statusResponse.descriptiveStatus
        Start-Sleep -s 10
    Write-Host "Downloading export file ..."
    $downloadRequest = $serverURL + '/interop/rest/11.1.2.3.600/applicationsnapshots/Export-' + $i + '.zip/contents'
    $statusResponse = Invoke-RestMethod -Uri $downloadRequest -Method Get -Headers $headers -OutFile "$exportFilePrefix-$i.zip"
    Write-Host "Expanding archive ..."
    Expand-Archive -Force -LiteralPath "$exportFilePrefix-$i.zip" -DestinationPath "$exportFilePrefix-$i"
    Remove-Item "$exportFilePrefix-$i.zip"
    Get-ChildItem -Path "$exportFilePrefix-$i" -File -Name | ForEach-Object { $exportFileArray += "$exportFilePrefix-$i\" +  $_ }
Write-Host "creating outputfile ..."
#write header to outputfile
Get-Content $exportFileArray[0] | Select-Object -First 1 | Out-File "$exportFilePrefix.csv"
#write content to outputfile skipping header
ForEach ($exportFile in $exportFileArray) {
    Get-Content $exportFile | Select-Object -Skip 1 | Out-File -Append "$exportFilePrefix.csv"
Compress-Archive -LiteralPath "$exportFilePrefix.csv"  -DestinationPath "$exportFilePrefix.zip"
Write-Host "cleaning up ..."
Remove-Item "$exportFilePrefix-*" -Recurse
Remove-Item "$exportFilePrefix.csv"
Bash 指令碼
#!/bin/bash
user='<USERNAME>'
pass='<PASSWORD>'
serverURL='<URL>'
applicationName='<APPLICATIONNAME>'
cubeName='<CUBENAME>'
splitDimension='<DIMENSION_TO_SPLIT_THE_EXPORT>'
topLevelMemberForExport='<TOP_MEMBER_FOR_EXPORT>'
exportJobName='<EXPORT_JOB_NAME>'
exportFilePrefix='<PREFIX_FOR_EXPORT_FILE>'
columnMembers='<MEMBERS_ON_COLUMNS>'
povMembers='<POV_MEMBERS>'
numberOfExportFiles=<NUMBER_OF_FILES_TO_SPLIT_THE_EXPORT>
getRowMembers() {
    local memberList="$1"
    local firstMember=$2
    local lastMember=$3
    local nameCount=0
    local rowMember=""
    local rowMembers=""
    while IFS= read -r line
    do
        if [[ "${line}" == *"name"* ]]
        then
            if [[ ${nameCount} -ge ${firstMember} ]] && [[ ${nameCount} -lt ${lastMember} ]]
            then
              rowMember=$(echo "${line}" | cut -d':' -f2- | sed s'/[",]//g')
              rowMembers="${rowMembers}${rowMember},"
            fi
            ((nameCount+=1))
        fi
    done <<< "${memberList}"
    rowMembers=$(echo "${rowMembers}" | rev | cut -d',' -f2- | rev)
getLevel0()
    local names=$(echo "${memberList}" | jq 'recurse (try .children[]) | .name' | sed -e 's/"//g')
    local elements=""
    formerIFS=$IFS
    IFS=$'\n'
    namesarr=($names)
    IFS=$formerIFS
    for i in ${!namesarr[@]}
    do
        testelement=$(echo "${memberList}" | jq --arg currentName "${namesarr[i]}" 'recurse (try .children[]) | select(.name==$currentName)')
        if [[ "${testelement}" != *"children"* ]]
        then
            elements="${elements}${testelement}"
        fi
    done
    echo "${elements}"
#test login
header="Content-Type: application/x-www-form-urlencoded"
applicationsRequest="${serverURL}/HyperionPlanning/rest/v3/applications"
response=$(curl -X "GET" -s -w "%{http_code}" -u "${user}:${pass}" -H "${header}" "${applicationsRequest}")
http_response_code=$(echo "${response}" | rev | cut -d'}' -f1 | rev)
if [ ${http_response_code} -ne 200 ]
then
    echo "${response}"
    exit
fi
echo "Retrieving member list for split dimension ${splitDimension}"
splitDimensionRequest="${serverURL}/HyperionPlanning/rest/v3/internal/applications/${applicationName}/plantypes/${cubeName}/dimensions/${splitDimension}"
response=$(curl -X GET -s -w "%{http_code}" -u "${user}:${pass}" -o "response-memberlist.txt" -D "respHeader-memberlist.txt" -H "${header}" "${splitDimensionRequest}")
then
    echo "${response}"
    exit
fi
echo "${splitDimension} member list retrieved"
echo "Searching for member ${topLevelMemberForExport} in hierarchy"
memberList=$(cat response-memberlist.txt | jq --arg topLevelMember "${topLevelMemberForExport}" 'recurse(try .children[]) | select (.name == $topLevelMember)')
if [[ "${memberList}" == "" ]]
then
    echo "${topLevelMemberForExport} not found in hierarchy, exiting ..."
    exit 128
fi
echo "Found member ${topLevelMemberForExport} in hierarchy"
#retrieve level 0 members in export hierarchy
echo "Retrieving Level 0 members for hierarchy"
totalCount=$(echo "${memberList}" | grep "name" | wc -l)
grepChildrenCount=$(echo "${memberList}" | grep "children" | wc -l)
levelZeroCount=$((totalCount-grepChildrenCount))
if [[ "${levelZeroCount}" -eq 0 ]]
then
    echo "no level 0 members found in hierarchy, exiting ..."
    exit 128
fi
echo "${levelZeroCount} Level 0 members for export hierarchy retrieved"
numberOfEntitiesPerFile=$((levelZeroCount/numberOfExportFiles))
jobsRequest="${serverURL}/HyperionPlanning/rest/v3/applications/${applicationName}/jobs"
header="Content-Type: application/json"
for ((i = 1 ; i <= ${numberOfExportFiles}; i++))
do
    firstMember=$((($i-1)*numberOfEntitiesPerFile))
    if [[ ${i} -lt ${numberOfExportFiles} ]]
    then
        lastMember=$((i*numberOfEntitiesPerFile))
    else
        lastMember=$((i*numberOfEntitiesPerFile+levelZeroCount%numberOfExportFiles))
    fi
    elements=$(getLevel0 "${memberList}")
    rowMembers=$(getRowMembers "${elements}" ${firstMember} ${lastMember})
    response=$(curl -X POST -s -w "%{http_code}" -u "${user}:${pass}" -o "response-job.txt" -D "respHeader-job.txt" -H "${header}" "${jobsRequest}" -d '{"jobType":"EXPORT_DATA","jobName":"'"${exportJobName}"'","parameters":{"exportFileName":"Export-'"${i}"'.zip","rowMembers":"'"${rowMembers}"'","columnMembers":"'"${columnMembers}"'","povMembers":"'"${povMembers}"'"}}')
    echo "Started export job " $i " out of " $numberOfExportFiles
    jobId=$(cat response-job.txt | grep -o '"jobId":[^, }]*' | cut -d':' -f2)
    descriptiveStatus=$(cat response-job.txt | grep -o '"descriptiveStatus":[^, }]*' | cut -d':' -f2 | sed -e 's/"//g')
    jobIdRequest="${serverURL}/HyperionPlanning/rest/v3/applications/${applicationName}/jobs/${jobId}"
    response=$(curl -X GET -s -w "%{http_code}" -u "${user}:${pass}" -o "response-jobstatus.txt" -D "respHeader-jobstatus.txt" -H "${header}" "${jobIdRequest}")
    jobId=$(cat response-jobstatus.txt | grep -o '"jobId":[^, }]*' | cut -d':' -f2)
    descriptiveStatus=$(cat response-jobstatus.txt | grep -o '"descriptiveStatus":[^, }]*' | cut -d':' -f2 | sed -e 's/"//g')
    while [[ "${descriptiveStatus}" == "Processing" ]]
    do
        echo "${descriptiveStatus}"
        sleep 10
    done
    echo "Downloading export file ..."
    contentsRequest="${serverURL}/interop/rest/11.1.2.3.600/applicationsnapshots/Export-${i}.zip/contents"
    curl -X GET -s -w "%{http_code}" -u "${user}:${pass}" -D "respHeader-download.txt" "${contentsRequest}" > "${exportFilePrefix}-${i}.zip"
    echo "Expanding archive ..."
    unzip "${exportFilePrefix}-${i}.zip" -d "${exportFilePrefix}-${i}"
    rm "${exportFilePrefix}-${i}.zip"
    echo "Writing to outputfile ..."
    if [[ -d "${exportFilePrefix}-${i}" ]]
    then
        find "${exportFilePrefix}-${i}" -name \*.csv | xargs cat | tail -n +2 >> "${exportFilePrefix}.csv"
    fi
done
zip "${exportFilePrefix}.zip" "${exportFilePrefix}.csv"
echo "cleaning up ..."
find . -name "${exportFilePrefix}-*" | xargs rm -r
rm "${exportFilePrefix}.csv"
要從聚總儲存 (ASO) 立方體中匯出大量儲存格:
  1. 複製 PowerShell 或 Bash 指令碼並將其儲存至您的檔案系統,例如,儲存為 ASOCellExport.ps1 或 ASOCellExport.sh。
  2. 修改指令碼檔案並設定參數值。請參閱下表以取得詳細資料。
    表格 3-16 要包含在 PowerShell 和 Bash 指令碼中的變數值
    變數 描述
    user 以 DOMAIN.USER 格式表示服務管理員網域與使用者名稱。
    範例:
    Windows:$user = 'exampleDomain.jDoe'
    Linux/UNIX:user = 'exampleDomain.jDoe'
    pass 服務管理員的密碼,或加密密碼檔案所在的位置。如需建立加密密碼檔案的相關資訊,請參閱 encrypt 命令。
    範例:
    Windows:$pass = 'Example'
    Linux/UNIX:pass = 'Example'
    serverURL Oracle Fusion Cloud Enterprise Performance Management 環境的 URL。
    範例:
    Windows: $serverURL = 'https://example .oraclecloud.com'
    Linux/UNIX: serverURL = 'https://example .oraclecloud.com'
    applicationName Planning、Financial Consolidation and Close、Tax Reporting 或 Enterprise Profitability and Cost Management 應用程式的名稱。
    範例:
    Windows:$applicationName = 'Vision'
    Linux/UNIX:applicationName = 'Vision'
    cubeName 應用程式中的立方體名稱。
    範例:
    Windows:$cubeName = 'VisASO'
    Linux/UNIX:cubeName = 'VisASO'
    splitDimension 用於將匯出分割為群組的維度成員名稱。
    範例:
    Windows:$splitDimension = 'Account'
    Linux/UNIX:splitDimension = 'Account'
    topLevelMemberForExport 維度子階層的成員名稱,在該階層下建立層級 0 成員的清單。
    範例:
    Windows:$topLevelMemberForExport = 'Total Cash Flow'
    Linux/UNIX:topLevelMemberForExport = 'Total Cash Flow'
    exportJobName 鍵入匯入資料的現有工作名稱。您在指令碼中設定的參數將覆寫此工作中指定的設定。
    範例:
    Windows:$exportJobName = 'ASO Cell Export'
    Linux/UNIX:exportJobName = 'ASO Cell Export'
    exportFilePrefix 檔案名稱前綴,用於唯一識別匯出工作產生的檔案。
    範例:
    Windows:$exportFilePrefix = 'cashflow'
    Linux/UNIX:exportFilePrefix = 'cashflow'
    columnMembers 要包含在匯出的成員欄。
    範例:
    Windows:$columnMembers = 'Period'
    Linux/UNIX:columnMembers = 'Period'
    povMembers
    要包含在匯出的檢視點。POV 成員必須包含所有其他維度,而且可以包含函式,如下所示:
    ILvl0Descendants(YearTotal), ILvl0Descendants(Year), ILvl0Descendants(Scenario), ILvl0Descendants(Version), ILvl0Descendants(P_TP), ILvl0Descendants(AltYear)
    範例:
    Windows:$povMembers = 'YTD'
    Linux/UNIX:povMembers = 'YTD'
    numberOfExportFiles 要為此匯出作業執行的工作數。如果由於查詢限制匯出仍然失敗,請增加此數字。
    範例:
    Windows:$numberOfExportFiles = 3
    Linux/UNIX:numberOfExportFiles = 3
  3. 使用 Windows 排程器或 cron 工作,安排指令碼在方便的時間執行。如需瞭解詳細步驟,請參閱自動執行指令碼。
