10200 - Remote Database Reinitialization in Progress
- Alarm Group:
- CFG
- Description:
- The remote database reinitialization is in progress. This alarm is raised on the active NOAM server for the server being added to the server group.
- Severity:
- Minor
- Instance:
- <hostname of remote server>
- HA Score:
- Normal
- Auto Clear Seconds:
- This alarm does not autoclear.
- OID:
- apwSgDbReinitNotify
Recovery:
- Check to see that the remote server is configured.
- Make sure the remote server is responding to network connections.
- If this does not clear the alarm, delete this server from the server group.
- It is recommended to contact My Oracle Support if further assistance is needed.
