22729 - PCRF Not Configured
- Alarm Group:
- PCA
- Description:
- Severity:
- Major
- Instance:
- Policy Binding Region Place Association Name
- HA Score:
- Normal
- Auto Clear Seconds:
- 0 (zero)
- OID:
- pdraPcrfNotConfiguredNotify
- Cause:
- This alarm raises when the P-DRA completes initialization and determines that the PCRF's are not configured.
- Diagnostic Information:
- Check the NOAM GUI at Main Menu > Policy and Charging > Configuration > Policy DRA for further PCRF configuration.
- Check for any missing configuration or capture this screen for further analysis.
Recovery:
- Check the NOAM GUI at for further PCRF configuration.
- Check the event history logs in Alarms & Events.
- If the problem persists, it is recommended to contact My Oracle Support.
