Installation of Oracle Linux 7.5 on Bootstrap Host
This procedure outlines the installation steps for installing the OL7 onto the OCCNE Installer Bootstrap Host. This host is used to configure the networking throughout the system and install OL7 onto RMS2. It is re-paved as a Database Host in a later procedure.
Prerequisites
Limitations and Expectations
References
Bootstrap Install Procedure
- USB drive of sufficient size to hold the ISO (approximately 5Gb)
- Oracle Linux 7.x iso
- YUM repository file
- Keyboard, Video, Mouse (KVM)
- The configuration of the Installer Bootstrap Host is meant to be quick and easy, without a lot of care on appropriate OS configuration. The Installer Bootstrap Host is re-paved with the appropriate OS configuration for cluster and DB operation at a later stage of installation. The Installer Bootstrap Host needs a Linux OS and some basic network to get the installation process started.
- All steps in this procedure are performed using Keyboard, Video, Mouse (KVM).
- Oracle Linux 7 Installation guide: https://docs.oracle.com/cd/E52668_01/E54695/html/index.html
- HPE Proliant DL380 Gen10 Server User Guide
Table 3-1 Bootstrap Install Procedure
| Step # | Procedure | Description |
1.
Create Bootable USB Media |
2.
Install OL7 on the Installer Bootstrap Host. |
3.
Install Additional Packages. |
Additional packages are needed to complete the installation
and move on to the next step in the overall procedure. These additional
packages are available within the OL install media on the USB. To install these
packages, a YUM repo file is configured to use the install media. The
additional packages to install are:
