OCCNE Automated Initial Configuration
Introduction
Common Services typically refers to the collection of various components deployed to OCCNE. The Common services are major functions in action which are able to perform logging, tracing, and metric collection of the cluster. To monitor the cluster and to raise alerts when an anomaly occurs or when a potential failure is round the corner. The below procedure are used to install the common services.Prerequisites
- All procedures in Kubernetes Installer is complete.
- The bastion host running the docker image must have docker installed.
- A defined and installed site hosts.ini file should also be present. Check Inventory File Preparation for instructions for developing this file.
A defined and installed site mb_configmap.yaml file should also be present in the same directory as hosts.ini. Check Populate the MetalLB Configuration File for instructions for developing this file.
- A docker image named 'occne/configure' must be available in the customer repository. Installation Procedure
- SNMP trap receiver should be setup in cluster reachable network (Optional: Required only for SNMP support)
Limitations and Expectations
Procedure Steps
All steps are executable from a SSH application (putty) connected laptop accessible via the Management Interface.
Table 3-16 Procedure to install common services
| Step # | Procedure | Description |
1.
Configure variables |
The following variables should be configured according to
customer needs, these variables can be modified to point to customer-specific
repositories and other configurations needing to be done in the hosts.ini files
as documented in the
Inventory File Template
2.
Run configure image | Run the configure image using the below
command. After "configure:" keyword put the tag of your latest pulled image.
$ docker run --rm -v /<PATH_TO_CLUSTER>/<CLUSTER_NAME>:/host <CUSTOMER-PROVIDED_REPOSITORY_LOCATION>/occne/configure:<RELEASE_TAG> Example: $ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit host_hp_gen_10[0:7],localhost" 10.75.200.217:5000/configure:1.2.0 Note: Replace the <release_tag> after "configure:" image name with the latest build tag. |
3.
Verify the services | After the above command successfully
completes, the services deployed and exposed can be verified by using the below
commandon the Bastion Host.
$ kubectl.sh get service --namespace=<NAMESPACE_VALUE> or $ kubectl.sh get service --all-namespaces Example: kubectl.sh get service --all-namespaces kubectl.sh get service --namespace=default kubectl.sh get service --namespace=kube-system kubectl.sh get srvices --namespace=occne-infra |
4.
Sample Output |
To verify if the above command was executed successfully and whether the services was installed properly, the output shown below can be taken as reference. NAMESPACE NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE default kubernetes ClusterIP 10.233.0.1 <none> 443/TCP 15d kube-system coredns ClusterIP 10.233.0.3 <none> 53/UDP,53/TCP,9153/TCP 2d22h kube-system tiller-deploy ClusterIP 10.233.49.220 <none> 44134/TCP 15d occne-infra occne-elastic-elasticsearch-client ClusterIP 10.233.32.176 <none> 9200/TCP 2d occne-infra occne-elastic-elasticsearch-discovery ClusterIP None <none> 9300/TCP 2d occne-infra occne-elastic-exporter-elasticsearch-exporter ClusterIP 10.233.30.32 <none> 9108/TCP 2d occne-infra occne-grafana LoadBalancer 10.233.50.235 10.75.207.165 80:30714/TCP 2d occne-infra occne-kibana LoadBalancer 10.233.35.35 10.75.207.161 80:31725/TCP 2d occne-infra occne-metrics-server ClusterIP 10.233.33.55 <none> 443/TCP 2d occne-infra occne-prometheus-alertmanager LoadBalancer 10.233.17.109 10.75.207.163 80:30894/TCP 2d occne-infra occne-prometheus-alertmanager-headless ClusterIP None <none> 80/TCP,6783/TCP 2d occne-infra occne-prometheus-kube-state-metrics ClusterIP None <none> 80/TCP 2d occne-infra occne-prometheus-node-exporter ClusterIP 10.233.32.132 <none> 9100/TCP 2d occne-infra occne-prometheus-pushgateway ClusterIP 10.233.12.53 <none> 9091/TCP 2d occne-infra occne-prometheus-server LoadBalancer 10.233.46.125 10.75.207.164 80:31467/TCP 2d occne-infra occne-tracer-jaeger-agent ClusterIP 10.233.47.176 <none> 5775/UDP,6831/UDP,6832/UDP,5778/TCP 2d occne-infra occne-tracer-jaeger-collector ClusterIP 10.233.11.191 <none> 14267/TCP,14268/TCP,9411/TCP 2d occne-infra occne-tracer-jaeger-query LoadBalancer 10.233.16.217 10.75.207.162 80:31628/TCP 99 |
5.
Remove configuration, if node fails. | If a node fail during configuration
deployment, the configuration can be removed using the following:
$ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <host_filter>,localhost --tags remove" <repo>/configure:<tag> Example: $ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit host_hp_gen_10[0:7],localhost --tags remove" 10.75.200.217:5000/configure:1.2.0 |
