OCNRF Configuration
This section describes about the OCNRF customization.
The OCNRF deployment is customized by overriding the default values of various configurable parameters.
Customize the yaml file
ocnrf-custom-values-1.2.0.yaml
as per the required parameters.
The
template can be downloaded from OHC.
Download the package
Network Repository
Function (NRF) Custom Template and Unzip to get
file.
Sample content of ocnrf-custom-values-1.2.0.yaml
- To download the
ocnrf-custom-values-1.2.0.yamlfile, refer section, OCNRF Deployment. - To know more about the configurable parameters, refer section OCNRF Configurable Parameters.
# Copyright 2019 (C), Oracle and/or its affiliates. All rights reserved.
# This yaml file could be supplied in helm install command when deploying OCNRF v1.2.0
# helm install ocnrf/ --name ocnrf --namespace <namespace> -f <this file>
# Compatible with OCNRF CHART VERSION 1.2.0
# I.
# Update the parameters in global and microservices sections
# 1.) Configure nrfName. This is unique deployment name for OC-NRF
# global.nrfName
# 2.) Set the hostname and port number of the primary and secondary sql nodes in
# global.mysql.primary.host
# global.mysql.secondary.host
# global.mysql.port
# global.mysql.database
# global.mysql.username
# global.mysql.password
# 3.) Set ambassador Id. Ambassador Id to uniquely identify the Ambassador instance in cluster.
# All 3 values below should be same.
# global.ambassadorId
# ambassador.ambassador.id
# ambassador.service.annotations.getambassador.io/config.ambassador_id
# 4.) Set ocnrf enpoint. Service Name for OC-NRF API-GW. Format:- NAME-endpoint
# Here NAME is helm release name.
# I.
# - To configure SCP as outbound proxy in NRF, if needed.
# set the SCP worker's k8s service name (<servicename>.<namespace> or <complete fqdn> and port in
# nfsubscription.http.proxy.host
# nfsubscription.http.proxy.port
# section:- global
global:
nrfName: "default-ocnrf"
jaeger:
service:
port: 9411
mysql:
primary:
host: "ocnrf-mysql"
secondary:
host: "ocnrf-mysql"
port: 3306
database: "nrfdb"
username: "xxxxxx"
password: "xxxxxx
endpoint: "ocnrf-endpoint"
endpointPort: 80
ambassadorId: "ocnrf-endpoint"
# section:- nfregistration
nfregistration:
image:
repository: ocnrf/ocnrf-nfregistration
tag: 1.2.0
pullPolicy: IfNotPresent
# section:- nfsubscription
nfsubscription:
image:
repository: ocnrf/ocnrf-nfsubscription
tag: 1.2.0
http:
proxy:
host:
port: 80
# section:- nrfauditor
nrfauditor:
image:
repository: ocnrf/ocnrf-nrfauditor
tag: 1.2.0
# section:- nfdiscovery
nfdiscovery:
image:
repository: ocnrf/ocnrf-nfdiscovery
tag: 1.2.0
nrfSupportedFeature: false
# section:- nrfconfiguration
nrfconfiguration:
image:
repository: ocnrf/ocnrf-nrfconfiguration
tag: 1.2.0
service:
configServiceNetworkNameEnabled: true
configServiceNetworkName: "metallb.universe.tf/address-pool: oam"
# section:- ambassador
ambassador:
fullnameOverride: ocnrf-endpoint
ambassador:
image:
repository: ocnrf/ocnrf-endpoint
tag: 0.50.3
podAnnotations:
prometheus.io/scrape: "true"
prometheus.io/port: "9102"
prometheusExporter:
repository: ocnrf/prom/statsd-exporter
tag: v0.8.1
service:
annotations :
metallb.universe.tf/address-pool: signaling
getambassador.io/config: |
apiVersion: ambassador/v1
kind: Module
ambassador_id: ocnrf-endpoint
config:
service_port: 8080
