OCNRF Installation Preparation
The following procedure describes the steps to download the OCNRF Images and Helm files from OSDC.
For more information about configuring docker image and registry, see chapter OCCNE Docker Image Registry Configuration in OCCNE Installation Guide 1.0.
Table 3-1 OCNRF Installation Preparation
| Step | Procedure | Description |
1
Download the OCNRF package file |
Customers are required to download the OCNRF package file from Oracle Software Delivery Cloud (OSDC). Package is named as follows: <nfname>-pkg-<marketing-release-number>.tgz
2
Untar the OCNRF Package File |
Untar the OCNRF package: tar -xvf <<nfname>-pkg-<marketing-release-number>>.tgz This command results into
The directory consists of following:
3
Verify the checksums | Verify the checksums of tarballs mentioned in
Readme.txt.
4
Load the tarball to system |
Execute the following command to load the images to the customer's local registry: docker load --input ocnrf-images-1.2.0.tar |
5
Check if all the images are loaded |
Execute the following command to check: docker images Refer the below table OCNRF Images for the list of images. |
6
Push docker images to docker registry |
Execute the following commands to push the docker images to docker registry:
7
Untar Helm Files |
Untar the helm files: tar -xvzf ocnrf-1.2.0.tgz |
8
Download the Network Repository Function (NRF) Custom Template ZIP file |
Download the Network Repository Function (NRF) Custom Template ZIP file from OHC:
OCNRF Images
Following are the OCNRF images:
Table 3-2 OCNRF Images
| Services | Image | Tag |
| NFRegistration |
ocnrf-nfregistration
1.2.0 |
| NFSubscription |
ocnrf-nfsubscription
1.2.0 |
| NFDiscovery |
ocnrf-nfdiscovery
1.2.0 |
| API-GW - ocnrf-endpoint |
ocnrf-endpoint
1.2.0 |
| NRF Auditor |
ocnrf-nrfauditor
1.2.0 |
| NRF Configuration | ocnrf-nrfconfiguration
1.2.0 |
