OCNRF Supported Services
This section includes information about the services supported by OCNRF.
OCNRF supports the following services:
OCNRF Management Services
The OCNRF Management service is identified by the service operation
name
Nnrf_NFManagement.
OCNRF supports the following management services:
The respective service operation name is mentioned next to each service.- Register NF instance
NFRegister): Allows an NF instance to register its NF profile in the OCNRF along with the list of services provided by the NF instance. - Update NF instance (
NFUpdate): Enables an NF instance to partially update or replace the parameters of its NF profile in the OCNRF. It also allows to add or delete services provided by the NF instance.This operation supports the following:- Complete Replacement of NF profile
- Partial Replacement of NF profile
- Add, Remove, or Update attributes of NF Profile
- Heart beat & Load info of NF
- De-register NF instance
NFDeregister): Enables an NF instance to de-register its NF profile and the services provided by the NF instance from the 5G network. - Subscribe to Status (
NFStatusSubscribe): Enables an NF instance to subscribe the status changes of other NF instances registered in the OCNRF. - Unsubscribe to Status
NFStatusUnsubscribe): Enables an NF instance to unsubscribe the status changes of other NF instances. - Receive Notifications of
Status (
NFStatusNotify): Enables the OCNRF to notify changes in status of NF instances to any subscriber of NF status. Changes also include information regarding newly registered and de-registered NFs.
OCNRF Discovery Services
The OCNRF Discovery service is identified by the service operation
name
Nnrf_NFDiscovery
Service.
OCNRF supports the following Discovery service:
The respective service operation name is mentioned next to the supported Discovery service.Discover NF
instance (NFDiscover): OCNRF
supports discovery of the IP address/FQDN of the NF instances, or NF Services
that match certain input criteria.
