Prerequisites
Following are the prerequisites to install and configure the SCP:
SCP Software
Following software are required as must to deploy the SCP:
Table 2-1 SCP Software
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.9.1 |
If any of the above services are needed and the respective software is not already installed in the CNE, then install the specified software items before proceeding.Network access
The Kubernetes cluster hosts must have network access to:
- Local docker image repository where the SCP images are available
- Local helm repository where the SCP helm charts are available
- Service FQDN of SCP must be discoverable from outside of the cluster (i.e., publicly exposed so that ingress messages to SCP can come from outside of Kubernetes).
All the kubectl and helm related commands used in this guide need to be executed on a system depending on the infrastructure/deployment. It could be a client machine such as a VM, server, local desktop, and so on.Client machine requirements
There are some requirements for the laptop/desktop where the
deployment commands need to be executed:
- It should have network access to the helm repository and docker image repository.
- Helm repository must be configured on the client.
- It should have network access to the Kubernetes cluster.
- It should have necessary
environment settings to run the
kubectlcommands. The environment should have privileges to create a namespace in the Kubernetes cluster. - It should have the helm
client installed with the
push plugin.
The environment should be configured so that the
helm installcommand deploys the software in the Kubernetes cluster.
SCP Images
Following are the SCP images:
Table 2-2 SCP Images
| Microservices | Image |
| SCP-Worker | scp-worker |
| SCPC-Pilot | scpc-pilot |
| SCPC-Soothsayer | soothsayer-configuration |
| soothsayer-notification | |
| soothsayer-subscription | |
| soothsayer-audit |
