How to use this document
Although this document is primarily to be used as an initial installation guide, its secondary purpose is to be used as a reference for Disaster Recovery procedures.
When executing this document for either purpose, there are a few points which help to ensure that the user understands the author’s intent. These points are as follows:
  1. Before beginning a procedure, completely read the instructional text (it will appear immediately after the Section heading for each procedure) and all associated procedural WARNINGS or NOTES.
  2. Before execution of a STEP within a procedure, completely read the left and right columns including any STEP specific WARNINGS or NOTES.
If a procedural STEP fails to execute successfully, STOP and contact Oracle’s Customer Service for assistance before attempting to continue. My Oracle Support for information on contacting Oracle Customer Support.
Figure 1-1 Example of a Procedure Steps Used in This Document
