OCSCP YAML File
Following is the sample OCSCP YAML file:
The OCSCP YAML file can also be downloaded from OHC.
global:
domain: svc.cluster.local
clusterDomain: cluster.local
# If you want to assign a load balancer IP,set loadbalanceripenbled flag to true and
# provide value for flag loadbalancerip
# else a random IP will be assigned if loadbalanceripenbled is false
# and it will not use loadbalancerip flag
publicSignalingIPSpecified: false
publicSignalingIP: 10.75.212.88
publicSignalingPort: 8000
adminport: 8001
scpInfo:
fqdn: scp-worker.scpsvc.svc.cluster.local
nfType: CUSTOM_ORACLE_SCP
nfStatus: REGISTERED
locality: Loc7 # Locality of SCP where its deployed.
mediation_status: DISABLED
customInfo:
mateScpInfo:
capacity: 500
priority: 1
mateSCPLocalities:
- Loc10
servingLocalities:
- Loc7
- Loc8
- Loc9
- USEast
remainingLocalities:
- Loc1
- Loc2
- Loc3
- Loc4
- Loc5
- Loc6
nfInstanceId: 6faf1bbc-6e4a-4454-a507-a14ef8e1bc5e # Sample value. User needs to update this nfInstanceId per his network
# NRF details for primary(Priority=0) and secondry(Priority=1) NRF. Note that these NRFs needs to be backend DB Synced.
# For Secondary NRF details always make it priority lesser than First priority NRF, currently we set secondary NRF priority to 1.
# In case of no secondry NRF user can comment the secondary NRF details
nrfDetails:
- nfType: []
nrfManagement:
fqdn: ocnrf-endpoint.ocnrf.svc.cluster.local
port: '80'
scheme: HTTP2
priority: 0 # Default value is 0
capacity: 100 # Default value is 100
apiPrefix: USEast
ipEndPoints:
- ipv4Address: 10.104.121.231
transport: TCP # Default value is TCP
port: 80 # Default value is 80
nrfDiscovery:
port: '80'
scheme: HTTP2
apiPrefix: USEast
ipEndPoints:
- nfType: []
nrfManagement:
fqdn: ocnrf2-ambassador.k1-nrf.svc.cluster.local
port: '80'
scheme: HTTP2
priority: 1 # Its value should be other than 0 since its lower priority nrf
apiPrefix: USEast
ipEndPoints:
- ipv4Address: 10.106.232.232
nrfDiscovery:
port: '80'
scheme: HTTP2'
priority: 1 # Default value is 0
apiPrefix: USEast
ipEndPoints:
# Audit NF List for which audit discovery needs to be triggered. If list is not provided or empty all valid NFs will be considered.
# NFs not part of nrfDetails will be ignored with warning.
auditNFList: []
scpc-soothsayer:
# registerScpWithNrf flag allows to specify whether user wants to start SCP registration with NRF.
# subscriptionInterval flag is now renamed to retryInterval.
subscription:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/soothsayer-subscription
tag: 1.2.0
pullPolicy: Always
resources:
memory: 1Gi
cpu: 0.5
serviceName: scpc-subscription
# Configure time interval in seconds to run Subscription and registration process. Value should be valid integer
retryInterval: 120
logLevel: INFO
registerScpWithNrf: false
notification:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/soothsayer-notification
tag: 1.2.0
pullPolicy: Always
resources:
memory: 4Gi
cpu: 3
serviceName: scpc-notification
logLevel: INFO
audit:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/soothsayer-audit
tag: 1.2.0
pullPolicy: Always
resources:
memory: 1Gi
cpu: 1
serviceName: scpc-audit
# Configure time interval in seconds to run Audit. Value should be valid integer
auditInterval: 120
logLevel: INFO
configuration:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/soothsayer-configuration
tag: 1.2.0
pullPolicy: Always
resources:
memory: 1Gi
cpu: 0.5
serviceName: scpc-configuration
logLevel: INFO
# This flag when set to True will consider NFs in SCP's locality if no locality information is present during their NF registration.
defaultLocalityToScp: true
# Configure Serviceto get profile from NRF. Possible values are 1. nnrf-nfm 2. nnrf-disc . User must have to use nnrf-nfm if interplmnfqdn is part of profile
nrfServiceForAudit: nnrf-nfm
# Configure reverseProxyEnabled at soothsayer level. Possible values can be either true or false.
reverseProxyEnabled: true configService:
publicConfigIPSpecified: false
publicConfigIP: 10.75.212.88
# If you want to provide a static nodePort, make staticnodeportenabled flag to true and
# provide value for flag nodeport ,
# else a random nodePort will be assigned if staticnodeportenabled is false
# and it will not use nodeport flag
staticnodeportenabled: false
# Port value should lie in between 30000-32767.
nodeport: 30002
# IP Address Pool from which should K8s config Service pick the IP Address
configServiceNetworkNameEnabled: false
configServiceNetworkName: "metallb.universe.tf/address-pool: oam"
nfServiceGroup:
- nfType: CHF
serviceName: nchf-spendinglimitcontrol
primaryLocalities:
- Loc7
- USEast
secondaryLocalities:
- Loc8
- Loc9
subsequentRequestRoutePolicy:
routePolicy: Forward_Proxy
reroutePolicy:
rerouteOptions: RerouteWithinRegion
- nfType: CHF
serviceName: nchf-convergedcharging
primaryRegionLocalities:
- Loc7
- USEast
secondaryRegionLocalities:
- Loc8
- Loc9
reroutePolicy:
scp-worker:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/scp-worker
tag: sprint_21_iteration_1
pullPolicy: Always
jaeger:
address: jaeger-collector.cne-infra.svc.cluster.local
port_value: 9411
# This flag tracingenable is used to enable or disable jaeger tracing
tracingenable: true
admin:
enablejaegerbody: false
retrytimeoutvalue: 5
service:
port:
nodeport: 30001
# IP Address Pool from which should K8s scp-worker Service pick the IP Address
networkNameEnabled: false
networkName: "metallb.universe.tf/address-pool: signaling"
loglevel: warning
prometheus:
scrape: true
resources:
memory: 4Gi # also update 'heapoverloadcontrol.resource_monitors.max_heap_size_bytes'
cpu: 4
minreplicas: 2
maxreplicas: 32
heapoverloadcontrol:
refresh_interval:
seconds: 0
nanos: 250000000
resource_monitors:
max_heap_size_bytes: 4294967296 #4096Mi
#Max heap size is 4GB. The values below are expressed as a fraction of the Max Heap Size
actions:
stop_accepting_requests: 0.70 #as fraction of max heap size
stop_accepting_connections: 0.75 #as fraction of max heap size
shrink_heap: 0.70 # as fraction of max heap size (min of all other threshold values)
scpc-pilot:
imageDetails:
image: ocspf-registry.us.oracle.com:5000/ocscp/scpc-pilot
pullPolicy: Always
enableTracing: true
minreplicas: 1
maxreplicas: 10
targetcpuutilpercent: 50 # To set Pilot Log level, by default it is set to info
logOutputLevel: "default:info" # To set Pilot Log Stack Trace Level,by default is set to none
logStacktraceLevel: "default:none"
resources:
memory: 6Gi
cpu: 4
