Limitation/Expectations
- It is expected that the
user is familiar with the use of OpenStack as a virtualized provider and the
OpenStack Client.
All OpenStack Client commands listed in this procedure are executed from the Bootstrap Host after it has been instantiated. - All necessary images, binaries, etc have been downloaded from Oracle OSDC prior to executing this procedure and these resources are available for use in this procedure.
- The customer has made available a central repository for all images, binaries, helm charts, etc, prior to executing this procedure.
The OpenStack commands in the procedures below are from a specific version of the OpenStack Desktop. The desktop used at the customer site may be slightly different depending on the version installed. The operations should be compatible.
