| 1.
Obtain the TLS Certificate for OpenStack
Depending on the Customer's environment it is very likely
that the customer's OpenStack uses certificates for TLS access to the API.
Without this certificate, OpenStack commands will not work. Customer's may have
to obtain this certificate before using OpenStack client commands.
- Ask the OpenStack
admin to provide the required TLS certificate to access the client commands
(ex. in an Oracle OpenStack system installed with kolla, the certificate will
be located at /etc/kolla/certiifcates/haproxy-ca.crt)
- Copy the
certificate to the Bootstrap Host at location:
/etc/pki/<OpenStack_release_name>/haproxy-ca.crt (ex.
/etc/pki/kolla/haproxy-ca.crt) (If /etc/pki/<OpenStack_release_name> does
not exist, it can be created using command:
mkdir
-p /etc/pki/<OpenStack_release_name>
- Set the
environment variable OS_CACERT to the location where the certificate was copied
to using the command:
export
OS_CACERT=/etc/pki/<OpenStack_release_name>/haproxy-ca.crt (ex.
export OS_CACERT=/etc/pki/kolla/haproxy-ca.crt)
| 2.
Get the Openstack RC (API v3) File
This file exports a number of environment variables on the
Bootstrap Host for the given user which directs the OpenStack Client commands
towards the particular OpenStack Environment. It must be copied to the users
home directory on the Bootstrap Host so that the OpenStack Client commands can
be executed.
These instructions may be somewhat different on OpenStack Desktops.
From the OpenStack Desktop: go to
Project →
Compute → Access & Security.
Select the API Access
- On the right hand
side, select Download OpenStack RC File v3.
This will download a openrc.sh file prefixed with the
OpenStack project name (ex: 5G-openrc.sh). to your PC.
SCP this file (ie. winSCP) to the Bootstrap Host in the
/home/admusr directory as .<project_name>-openrc.sh
Note: In order for
SCP/winSCP to work properly, the key mentioned in the Prerequisites above must
be used to access the Bootstrap Host. It may also be necessary to add the
appropriate Security Group Rules to support SSH (Rule: SSH, Remote: CIDR CIDR:
0.0.0.0/0) under the
Network →
Security Groups page in the OpenStack Environment. Contact the OpenStack
Administrator to get the proper rules added if necessary.
Execute the following command:
source
- Execute the
following command to verify the OpenStack Client is working:
openstack image list
| 3.
Create SSH Key on Bootstrap Host
Create the keys that will be used to access
the other VMs. This command generates the private and public keys that are
passed to the Bastion Host and used to communicate to other node from that
Bastion Host. Do not supply a passphrase when it asks for one. Just hit enter.
Also the private key should be copied to a place for safe keeping should the
Bootstrap Host be destroyed.
$ ssh-keygen -m PEM -t rsa -b 2048
| 4.
Add Files to /tmp Directory
These files must be copied to the directories listed using
scp or some other means (ie. winSCP).
There are three directories on the Bootstrap Host. These
three directories are as follows:
/tmp/yum.repos.d
/tmp/db
/tmp/certificates
Within these three directories the user must supply the
following mandatory files:
Add a customer specific central repo .repo file to the
/tmp/yum.repos.d directory which allows for access to the customer specific
repo (ex: winterfell-mirror.repo).
Add a mysql .zip file. (ex: V980756-01.zip) to the
/tmp/db directory. This file is used for installing the ndb MySQL cluster and
is downloaded from OSDC.
- Add a docker
registry certificate to the /tmp/certificates directory for the central docker
registry. This file mus tbe copied using the following
format:<central_repo_hostname>:<central_repo_port>.crt(ex:
winterfell:5000.crt).
| 5.
Updating the
~.configure/openstack/clouds.yaml File
- To obtain the
values for the authorization fields need in clouds.yaml below, execute the
openstack configuration show
command (make sure you have sourced the openrc
script before executing this command).
$ openstack configuration show
| Field | Value |
| api_timeout | None |
| application_catalog_api_version | 1 |
| auth.auth_url | http://thundercloud.us.oracle.com:5000/v3 |
| auth.password | <redacted> |
| auth.project_domain_id | 6c3468f1207c4e00bb441746c2046a90 |
| auth.project_id | 811ef89b5f154ab0847be2f7e41117c0 |
| auth.project_name | OCCNE |
| auth.user_domain_name | LDAP |
| auth.username | John.Doe |
| auth_type | password |
| baremetal_api_version | 1 |
| beta_command | False |
| cacert | None |
| cert | None |
| compute_api_version | 3 |
| container_api_version | 1 |
| container_infra_api_version | 1 |
- To get the
floating_network_id value for the load balancer configuration in clouds.yaml
below, execute the following commands:
$ openstack network list
Get the network ID and the subnets id for floating ip
address network name:
Example from the openstack command cli list:
| ID | Name | Subnets |
| e4351e3e-81e3-4a83-bdc1-dde1296690e3 | ext-net | c0e0c185-ed65-4a53-a7a3-418277fb9a20 |
- Edit the
~/.configure/openstack/clouds.yaml file (using sudo vi
~/.configure/openstack/clouds.yaml) and update following values for your
Openstack Environment using the commands listed above (use double quotes where
indicated in the example given below):
clouds:
mycloud:
auth:
auth_url: <openstack-Identity-api-url>
username: <openstack-user-name>
project_name: <openstack-project-name>
project_id: <openstack-Project ID>
user_domain_name: <openstack-Domain Name>
password: <openstack-user-password>
region_name: <openstack-region-name-if-available>
interface: <openstack-intrface- public/private>
identity_api_version: <openstack-indentity-api-version>
loadbalancer:
lbaas_enabled: true
subnet_id: <openstack_lbaas_subnet_id>
floating_network_id: <openstack_lbaas_floating_network_id>
use_octavia: true
lb_method: ROUND_ROBIN
Example:
clouds:
mycloud:
auth:
auth_url: http://thundercloud.us.oracle.com:5000/v3
username: "john.doe"
project_name: "OCCNE"
project_id: 811ef89b5f154ab0847be2f7e41117c0
user_domain_name: "LDAP"
password: "johnspw"
region_name: "RegionOne"
interface: "public"
identity_api_version: 3
loadbalancer:
lbaas_enabled: true
subnet_id: c0e0c185-ed65-4a53-a7a3-418277fb9a20
floating_network_id: e4351e3e-81e3-4a83-bdc1-dde1296690e3
use_octavia: true
| 6.
Updating cluster.tfvars File
The fields in the cluster.tfvars file must
be configured to adapt to the current customer Openstack Environment. The steps
below detail how to collect and set the fields that must be changed.
- From the
/var/terraform directory, copy directory occne_example and its contents
(cluster.tfvars) using the command below to create a new directory. Change the
name of the new directory to include your name to distinguish it from the
occne_example directory.
Note: The directory name is
not used for any special purpose other than to distinguish it from the
occne_example directory. It can be called anything.
$ cp -R occne_example occne_<user>
- Use the following
commands to retrieve the information necessary to configure the cluster.tfvars
- The different
flavor settings should be set according to the recommendations from Reference 1
in this document. An Admin user of the customer specific OpenStack Environment
must add the flavors and provide the UUID of those flavors for configuration
into the cluster.tfvars file. The UUID of each specific flavor that is used
must be added as the value field of the key/value fields in the cluster.tfvars
file.
- Once flavors
have been added to the OpenStack Environment, the UUID can be retrieved via the
following OpenStack Client command from the Bootstrap Host shell:
$ openstack flavor list | grep <flavor_name>
Example:
$ openstack flavor list | grep medium
| 43c7b73b-42a7-4f40-b52e-11f6803fc750 | oc-cne.medium | 16384 | 80 | 0 | 2 | True |
$ openstack flavor show 43c7b73b-42a7-4f40-b52e-11f6803fc750
| Field | Value |
| OS-FLV-DISABLED:disabled | False |
| OS-FLV-EXT-DATA:ephemeral | 0 |
| access_project_ids | None |
| disk | 80 |
| id | 43c7b73b-42a7-4f40-b52e-11f6803fc750 |
| name | oc-cne.medium |
| os-flavor-access:is_public | True |
| properties | |
| ram | 16384 |
| rxtx_factor | 1.0 |
| swap | |
| vcpus | 2 |
- Use the
following command to retrieve the floatingip_pool name and external_net UUID.
| 1d25d5ea-77ca-4f56-b364-f53b09292e7b | ext-net2 | f5c5ee71-8688-466d-a79f-4306e2bf3f6a |
| 668bc488-5307-49ad-9332-24fb0767bb39 | test-network | 9432b2d5-99c0-43ee-8f8c-4709f38b68d9 |
| 903155c7-c3ff-4283-bc2b-f34e8b6e76b0 | occne-ebadger-tc1 | ecbadd3e-e239-4830-b8c1-5ff94fa64c3a |
| 90c160aa-2ef7-47d3-a212-e1790d56c971 | ext-net-ipv6 | 4c0b844f-1557-4454-b561-88fa31f657f3 |
| c4a7569b-5448-4add-8c4e-006bbdd984ef | cluster1 | 4cf62be3-05e9-4a5b-b2a9-6aceee3c860f |
| fc36d63f-b30b-4c7f-979f-9b52b614bbd7 | occne-mkingre | 7631612f-5d22-49be-975c-6e0a9329339b |
- Navigate to
occne_<user> directory and edit the contents of the cluster.tfvars file
in the newly created directory:
$ vi occne_<user>/cluster.tfvars
- The fields in the
cluster.tfvars file must be configured to adapt to the current customer
Openstack Provider. Initially the cluster_name and network_name should be set
as the same value.
# <Kubernetes cluster name here>
cluster_name = "<cluster-name>"
# networking
network_name = "<cluster-name>"
- For setting the
ntp_server value in the cluster.tfvars file, use the IP Address of your cloud
URL. One way of obtaining this is using the ping command on your Bootstrap
Host. (For example:
ping
thundercloud.us.oracle.com)
$ ping thundercloud.us.oracle.com
PING srv-10-75-171-2.us.oracle.com (10.75.171.2) 56(84) bytes of data.
64 bytes from pc1011601.labs.nc.tekelec.com (10.75.171.2): icmp_seq=1 ttl=63 time=0.283 ms
| 7.
Updating the clouds.yaml file for Load
Balancers
Note: This must be executed after updating the
cluster.tfvars file
- Get the subnet_id
value by running following terrform commands:
$ terraform init
$ terraform apply -auto-approve -var-file=occne_<user>/cluster.tfvars
- After successful
run of terraform apply, run following OpenStack command to get the subnet_id.
- Copy the value
from subnets column for the name that is same as the cluster_name from
- Edit the
~/.configure/openstack/clouds.yaml) and update the subnet_id value keeping
other values previously configured the same.
loadbalancer:
lbaas_enabled: true
subnet_id: <cluster_name_subnet_id>
Example ((using cluster name: test-network):
loadbalancer:
lbaas_enabled: true
subnet_id: 9432b2d5-99c0-43ee-8f8c-4709f38b68d9
