Installation Procedures
The installation procedures in this document provision and configure an Oracle Communications Signaling, Network Function Cloud Native Environment (OCCNE). OCCNE 1.3 offers the choice of deployment platform; the CNE can be deployed directly onto dedicated hardware, (referred to as a bare metal CNE), or deployed onto OpenStack-hosted VMs. (referred to as a virtualized CNE).
Regardless of which deployment platform is selected, OCCNE installation is highly automated. A collection of container-based utilities are used to automate the provisioning, installation, and configuration of OCCNE. These utilities are based on the following automation tools:
- PXE helps reliably automate provisioning the hosts with a minimal operating system.
- Terraform is used to create the virtual resources that the virtualized CNE is hosted on.
- Kubespray helps reliably install a base Kubernetes cluster, including all dependencies (like etcd), using the Ansible provisioning tool.
- Ansible is used to orchestrate the overall deployment.
- Helm is used to deploy and configure common services such as Prometheus, Grafana, ElasticSearch and Kibana.
In case any procedure requires Linux Shell access, make sure that the shell is with Keepalive to avoid unexpected timeout.
