Go to primary content
Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide
Release 1.0
F16981-02
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Installation Sequence
This section informs about the sequence in which NRF must be installed.
Table 3-1 Installation Sequence
Sl.No Phase Description
1 Installation Preparation Download the required files and load the files to the system.
2 Configure <ocnrf_customized_values.yaml> file.
This includes configuring the following based on the deployment:
  1. Repository path
  2. Primary and Secondary node
  3. NRF details
Note: Other configurations might be changed based on the deployment.
NRF deployment NRF can be deployed in either of the following ways:
  • With HELM repository
  • With HELM tar
Verify NRF deployment Check if the services and pods are up and running.
NRF Images
Following are the NRF images:
Table 3-2 NRF Images
Services Image
NFRegistration ocnrf-nfregistration
NFSubscription ocnrf-nfsubscription
NFDiscovery ocnrf-nfdiscovery
API-GW - ocnrf-endpoint ocnrf-ambassador, prom/statsd-exporter
NRF Auditor ocnrf-nrfauditor
