Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
This section includes information about the allowed configurable options on NRF micro services that needs to be updated only during the deployment using helm chart.
svc.cluster.local
NRF allows customization of parameters for the following services and related settings:
nfregistration
Table 2-1 NF Registration
Service | Parameter | Description | Default value | Range or Possible Values (If applicable) | Notes |
nfregistration | fullnameOverride | Full Name of Microservice with Helm Release name | ocnrf-nfregistration | Not applicable | Format:- NAME-nfregistration |
image.repository | Full Image Path | reg-1:5000/ocnrf-nfregistration | Not applicable | ||
image.tag | Tag of Image | latest 1.0.0 | Not applicable | ||
image.pullPolicy | This setting will tell if image need to be pulled or not | Always | Possible Values - Always IfNotPresent Never | ||
mysql.primary.host | Primary MYSQL Host IP or Hostname | ocnrf-mysql | Not applicable | NRF will connect Primary MYSQL if not available then it will connect secondary host. Format:- NAME-mysql For MYSQL Cluster use respective IP Address or Service | |
mysql.secondary.host | Secondary MYSQL Host IP or Hostname | ocnrf-mysql | Not applicable | Format:- NAME-mysql For MYSQL Cluster use respective Secondary IP Address or Service | |
mysql.port | Port of MYSQL Database | 3306 | Not applicable | ||
mysql.username | Mysql Username for NRF database set by MYSQL DBA | nrfusr | Not applicable | ||
mysql.password | Mysql password for NRF database set by MYSQL DBA | Not applicable | |||
mysql.database | Mysql Database name for NRF | nrfdb | Not applicable | ||
minReplicas | Minimum Replicas | 2 | Not applicable | Minimum number of pods | |
maxReplicas | Maximum Replicas | 7 | Not applicable | Maximum number of pods | |
ambassador.id | Ambassador Identification | ambassador-ocnrf | Not applicable | There can be multiple Ambassador installed in same cluster for different NFs. So, this is unique identification for it. Format:- ambassador-NAME | |
sub.svc.host | NFSubscription Microservice | ocnrf-nfsubscription | Not applicable | Format:- NAME-nfsubscription | |
sub.svc.port | NFSubscription Microservice port | 8080 | Not applicable | ||
nf.heartbeat.duration | NF HeartBeat Duration after which heartbeat will be treated as missed | 90s | Not applicable | This value will be sent in response of NF registration request | |
nf.notify.loadThreshold | Notification trigger will happen at least Load Threshold changes percent during NF update | 5 | Not applicable | ||
disc.validityperiod | Discovery Validity Period after which NF should do discovery again | 1h | Not applicable | ||
hplmn.mcc | NRF Home PLMN MCC | 310 | Not applicable | Configure the MCC of NRF same as other NF. | |
hplmn.mnc | NRF Home PLMN MNC | 14 | Not applicable | Configure the MNC of NRF same as other NF. | |
jaeger.service.name | Jaegar Service Name installed in CNE | occne-tracer-jaeger-collector.occne-infra | Not applicable | ||
jaeger.service.port | Jaegar Service Port installed in CNE | 9411 | Not applicable | ||
reg.svc.ext.host | Registration Service Host exposed outside to NRF | ocnrf- endpoint | Not applicable | Format:- NAME-endpoint | |
reg.svc.ext.port | Registration Service External Port exposed outside to NRF | 80 | Not applicable | ||
reg.svc.host | Registration Service Host in NRF | ocnrf-nfregistration | Not applicable | Format:- NAME-nfregistration | |
reg.svc.port | Registration Service Port in NRF | 8080 | Not applicable | ||
noproxy | Microservice which can talk without proxy | ocnrf-nfsubscription, ocnrf-endpoint | Not applicable | Format:- NAME-nfsubscription, NAME-endpoint | |
log.level | Logging level | INFO | INFO, DEBUG, FATAL, ERROR, WARN |
NF Subscription Micro
service (nfsubscription
Table 2-2 NF Subscription
nfsubscription | fullnameOverride | Full Name of Microservice with Helm Release name | ocnrf -nfsubscription | Not applicable | Format:- NAME-nfsubscription |
image.repository | Full Image Path | reg-1:5000/ ocnrf-nfsubscription | Not applicable | ||
nfsubscription | This setting will tell if image need to be pulled or not | Always | Possible Values -
mysql.primary.host | Primary MYSQL Host IP or Hostname | ocnrf -mysql | Not applicable | NRF will connect Primary MYSQL if not available then it will connect secondary host. Format:- NAME-mysql For MYSQL Cluster use respective IP Address or Service | |
mysql.secondary.host | Secondary MYSQL Host IP or Hostname | ocnrf -mysql | Not applicable | Format:- NAME-mysql For MYSQL Cluster use respective Secondary IP Address or Service | |
reg.svc.host | NFRegistration Microservice Host | ocnrf -nfregistration | Not applicable | Format:- NAME-nfregistration | |
reg.svc.port | NFRegistration Microservice Port | 8080 | Not applicable | ||
reg.svc.ext.port | Registration Service Port exposed outside to NRF | 80 | Not applicable | ||
http.proxy.host | Hostname of Proxy for HTTP | Not applicable | |||
http.proxy.port | Port of Proxy for HTTP | 80 | Not applicable | ||
https.proxy.host | Hostname of Proxy for HTTPS | Not applicable | |||
https.proxy.port | Port of Proxy for HTTPS | 80 | Not applicable | ||
sub.svc.host | NFSubscription Microservice Host | ocnrf -nfsubscription | Not applicable | Format:- NAME-nfsubscription | |
sub.svc.port | NFSubscription Microservice Port | 8080 | Not applicable | ||
sub.svc.ext.host | Subscription Service Host exposed outside to NRF | ocnrf- endpoint | Not applicable | Format:- NAME-endpoint | |
sub.svc.ext.port | Subscription Service Port exposed outside to NRF | 80 | Not applicable | ||
sub.svc.validityDuration.min | Subscription Validity Duration Minimum | 1h | Not applicable | ||
sub.svc.validityDuration.default | Subscription Validity Duration Default | 90d | Not applicable | ||
sub.svc.validityDuration.max | Subscription Validity Duration Maximum | 180d | Not applicable | ||
noproxy | Microservice which can talk without proxy | ocnrf -nfregistration, ocnrf-endpoint | Not applicable | Format:- NAME-nfregistration, NAME-endpoint | |
nrfauditor
Table 2-3 NRF Auditor
nrfauditor | fullnameOverride | Full Name of Microservice with Helm Release name | ocnrf -nrfauditor | Not applicable | Format:- NAME-nfauditor |
image.repository | Full Image Path | reg-1:5000/ocnrf-nrfauditor | Not applicable | ||
image.tag | Tag of Image | latest 1.0.0 | |||
mysql.primary.host | Primary MYSQL Host IP or Hostname | OCNRF -mysql | NRF will connect Primary MYSQL if not available then it will connect secondary host. Format:- NAME-mysql For MYSQL Cluster use respective IP Address or Service | ||
mysql.secondary.host | Secondary MYSQL Host IP or Hostname | OCNRF -mysql | Format:- NAME-mysql For MYSQL Cluster use respective Secondary IP Address or Service | ||
mysql.port | Port of MYSQL Database | 3306 | |||
mysql.username | Mysql Username for NRF database set by MYSQL DBA | nrfusr | |||
mysql.password | Mysql password for NRF database set by MYSQL DBA | ||||
mysql.database | Mysql Database name for NRF | nrfdb | |||
sub.svc.host | NFSubscription Microservice Host | ocnrf-nfsubscription | Format:- NAME-nfsubscription | ||
sub.svc.port | NFSubscription Microservice Port | 8080 | |||
nf.heartbeat.duration | NF HeartBeat Duration after which heartbeat will be treated as missed | 90s | Not applicable | ||
nf.suspend.duration | Suspend duration after which profile will be deleted | 7d | Not applicable | ||
nf.heartbeat.missAllowed | NF HeartBeat miss allowed after which profile will be marked as suspended | 3 | Not applicable | ||
ambassador
Table 2-4 Ambassador
Ambassador | fullnameOverride | Full Name of Microservice with Helm Release name | ocnrf- endpoint | Not applicable | Format:- NAME-endpoint |
ambassador.id | Ambassador Identification | ambassador-ocnrf | Not applicable | There can be multiple Ambassador installed in same cluster for different NFs. So, this is unique identification for it. | |
image.repository | Full Image Path | quay.io/datawire/ambassador | Not applicable | ||
image.tag | Tag of Image | 0.50.3 | Not applicable | ||
service.annotations. getambassador.io/config.ambassador_id |
ambassador-ocnrf |
Not applicable |
podAnnotations. prometheus.io/scrape |
Prometheus related setting | true |
Possible Values - true false |
podAnnotations. prometheus.io/port |
Prometheus related setting | 9102 | |||
prometheusExporter.enabled | Prometheus related setting | true |
nfdiscovery
Table 2-5 NF Discovery
Service | Parameter | Parameter | Description | Range or Possible Values (If applicable) | Notes |
nfdiscovery | fullnameOverride | Microservice Full Name with Helm Release name | ocnrf -nfdiscovery | Format:- NAME-nfdiscovery | |
image.repository | Full Image Path | reg-1:5000/ocnrf-nfdiscovery | |||
image.pullPolicy | This setting tells if image need to be pulled or not | Always | Possible Values -
mysql.primary.host | Primary MYSQL Host IP or Hostname | ocnrf -mysql | NRF first connects to Primary MYSQL, if that
is not available then it connects secondary host.
Format:-
mysql.secondary.host | Secondary MYSQL Host IP or Hostname | ocnrf -mysql | Format:-
NAME-mysql
ambassador.id | Ambassador Identification | ambassador-ocnrf | There can be multiple Ambassador installed in
Format:-
ambassador-NAME
disc.validityperiod | Discovery Validity Period after which NF should do discovery again | 1h | |||
disc.result.profiles | Discovery Micro service will return the response with profiles count limited to the configured value | 3 | 1-10 | Unset the value to disable this feature. In case the configured value is less than the configured range then minimum value of the range is considered, similarly if the configured value is more than the configured range then maximum value of range is considered. | |
disc.result.loadThreshold | Discovery Micro service will return the response with profiles with NF Profile Load less than the configured value | 0-100 | Unset the value to disable this feature. This is disabled by default. In case the configured value is less than the configured range then minimum value of the range is considered, similarly if configured value is more than the configured range then maximum value of range is considered. | ||
