Pre-requisites
Following are the pre-requisites you must have before proceeding with the Cloud Native User Data Repository installation.
Oracle Communications User Data Repository Software
The Oracle Communications User Data Repository software consists of:
- Oracle Communications User Data Repository Helm Chart - It reflects the Oracle Communications User Data Repository software version. It comes in form of a zipped tar file.
- Software images of the micro-services. They come in form of docker images and/or tar file.
The following software must be installed.
| Software | Version |
| Kubernetes | v1.13.3 |
| HELM | v2.12.3 |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Metrics Area |
| prometheus | 8.8.0 | Needed for Metrics Area |
| prometheus-node-exporter | 1.3.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metric Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE, install software before proceeding.Note:
Some of the above mentioned softwares are updated frequently. Later versions than those listed above should work with UDR 1.3. Some UDR features and services behave or work differently depending on the software being used.Create Database User/Group
The UDR uses a NDB MySQL database to store the subscriber information.
The UDR deployment using MySQL NDB cluster requires the database administrator to create user in MYSQL DB and to provide the user with necessary permissions to access the tables in the NDB cluster.
- Login to the server where the ssh keys are stored and SQL nodes are accessible.
- Connect to the SQL nodes.
- Login to the Database as a root user.
- Create a user and assign
it to a group having necessary permission to access the tables on all the SQL
nodes:
CREATE USER '<username>'@'%' IDENTIFIED BY '<password>'; DROP DATABASE if exists udrdb; CREATE DATABASE udrdb CHARACTER SET utf8; GRANT SELECT, INSERT, CREATE, ALTER, DROP, LOCK TABLES, CREATE TEMPORARY TABLES, DELETE, UPDATE,EXECUTE ON udrdb.* TO '<user>'@'%'; USE <db_name>;
Network access
The Kubernetes cluster hosts must have network access to:
- quay.io/datawire/ambassador docker image repository
- Local docker image repository where the Oracle Communications User Data Repository images are available
- Local helm repository where the Oracle Communications User Data Repository helm charts are available
Laptop/Desktop Client software
Following are the requirements for the laptop/desktop where the deployment commands shall be executed:
- Network access to the helm repository and docker image repository
- Helm repository must be configured on the client
- Network access to the Kubernetes cluster
- Necessary environment
settings to run the
kubectlcommands. The environment should have privileges to create namespace in the Kubernetes cluster. - Helm client installed with
the
push plugin.
The environment should be configured so that the
'helm install'command deploys the software in the Kubernetes cluster.
All the kubectl and helm related commands that are used in this document must be executed on a system depending on the infrastructure of the deployment. It could be user machine such as VM, server, local desktop and so on.
