ATS Features
The ATS features are as follows:
- Provides an end-to-end
solution to the customers for testing Oracle Communications 5G-NFs. The ATS
package includes:
- Test scripts and docker
images of test container
- The docker images have complete framework and libraries installed, which is common for all NFs working with BDD framework
- Docker image of HTTP Server simulator
- Helm chart to deploy the ATS (delivered as a tar file)
- Readme text file (.txt file)
- Enables all the NF teams with the basic environment, framework and a GUI (Jenkins) to execute all the functional test cases
